Dumping fuel
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Dumping fuel
Yesterday took out the car and opened it up for the first time.
First few times everything seemed fine.
Then the last time it started to smoke, stalled out. Pulled off the road and noticed a glowing red piece of guts from the cat looked under the car and the cat was glowing red.
Waited 20 mins eased it 2 miles home.
This morning started it up and it STINKS like fuel stalls out unless I hold the throttle a little bit.
WHere should I start? What could of happened? Fuel injectors were just replaced 2 weeks ago....
Engine: 5.7 L98
Re: Dumping fuel
yeah i know, but thats the result of teh problem, not the problem itself
Engine: 4++,350 & 305 CIs
Re: Dumping fuel
Check your fuel PSI regulator vac hose for raw fuel. If you have some your diaphram is bad.
Engine: 5.7 L98
Re: Dumping fuel
i pulled it off the TB nothing came out, should i be checking the other end off the regulator? although that was changed at the same time as all the injectors about 2-3 weeks ago...
when fuel pressure was set it was set at 48psi at idle with vacuum line off. could fuel pressure be to high at WOT?
thinking maybe too much fuel, destroyed cat and not it wont run because backpressure is altered if the cat is destroyed.... is that possible?
although i guess that dont explain why as soon as i start it im smelling raw fuel
Engine: 5.7 L98
Re: Dumping fuel
actually more i think about it thats probably just wishful thinking, i probably f'd something up at 100 mph on a new engine with only 175 miles or so on it
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Engine: 5.7 L98
Re: Dumping fuel
My motors get run hard from day one.. (all mine are roller cams)
92camaroJoe
Aug 13, 2015 06:07 AM
