What would a small cam do to a 305 TPI?
Old Apr 8, 2012 | 02:40 PM
fig-newton's Avatar
Car: 1987 Camaro IROC-Z
Transmission: 700R4!
What's goin on guys, this is Dave "Fig Newton" and I got a question about my 87' IROC-Z. Its the car I got in High School and I'm fixin it up now. Motor in it now is bad and I'm puttin another 305 in my shop in it. I ordered a few parts like headers and ignition for a little extra ummph. I'm going to be driving the car to work and was wonderin how bad my mpg would hurt with a little cam and which is a good one to get. How much hp would a little one make and how much torque would it take way?
Thanks and merry christmas
-Fig Newton
Old Apr 9, 2012 | 11:50 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: What would a small cam do to a 305 TPI?
TPI motors are really good for torque, and 'run out of gas' right around 5K RPM.... so, pick a cam that builds it's power lower in the RPM range. Compare what you are considering to the stock cam.... the 305's actually came with a half-way decent one from the factory. Sorta...
Old Apr 11, 2012 | 10:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
305s got a different cam depending on what transmission the car came with. The automatic cars got a garbage cam. The 5 speed cars got the L98 cam, which isn't a terrible cam for a 305.
Specs:
87 350,305man = 4093643 202/207 .404/.415 114.5
87 305 auto = 10088155 179/194 .350/.384 109deg
Old Apr 11, 2012 | 03:52 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I put a cam in my little 305. It woke it up a little. Plus makes power to 5500 ish.
Plus it sounds a lot better at idle. Make sure you change your springs and while your in there change your valve seals. Best of luck!
Old Apr 11, 2012 | 04:28 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Do you have to worry about emissions? Are you going to leave it stock other than the cam?
Old Apr 11, 2012 | 07:19 PM
Eleanor62's Avatar
Old Apr 11, 2012 | 07:26 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
I'm going to go down the same road as yaj15 is eluding to. The cam is only one piece of a complete system. To gain the most benefit from it, you are going to need to address the other systems, like exhaust and intake.
Old Apr 11, 2012 | 09:51 PM
87z28guy's Avatar
Car: 87 iroc z
Engine: lt1
Transmission: t56
Axle/Gears: posi 3.42
if its an auto the lt1 cam would be a nice little upgrade
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
