350 tpi idle weird
Old May 1, 2012 | 02:54 AM
smash92RS305's Avatar
Car: 89 Firebird Formula 350
Engine: 5.7L TPI Roller motor
Transmission: 700R4 built
350 tpi idle weird
Ok, I have an 89 firebird formula with the 350 tpi and it idles weird. First of all yes, I tried cleaning the iac, properly setting idle, changing tps to.054 volts. That was all I could think of. Here's my symptoms, I start it up, it wants to die when cold, like the iac isn't opening, a few mins later it will stay running, then once it warms up it idles at 1400 rpm, its like the idles for warmed up, and cold start are backwards. Can anybody recommend anything else to check or what the problem may be? I know the iac could be bad but for a $100 electrical part, I don't want to change it unless I know its the problem. Thanks in advance, Garrett.
Old May 1, 2012 | 03:45 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
Re: 350 tpi idle weird
if the coolant temp sensor is bad, or not plugged in it causes that to happen. i hooked up a snap on machine to my car, it was reading -39 degrees. wouldnt stay running for the life of me when it was cold. once it got up to temp it ran better.. just not great. replaced coolant temp sensor, all of that went away. i know the 305 tpi has them underneath the hose under the throttlebody. not to sure if the 350 tpi's were the same set up, id assume for the most part they were. good luck.
Old May 1, 2012 | 08:53 AM
Yeah its in that same spot, that would make sense why it would run like that, ill try to swap it out and post back
Old May 2, 2012 | 03:59 PM
Ok, replaced the coolant temp sensor, and it seemed better for a day now its still stalling when cold. Anymore idle problem ideas? Edit: high idle when hot, and low idle when cold still a problem
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
