i need help with my 305 tpi
Subscribe
May 1, 2012 | 05:13 PM
hi guys i've been having problems with my 305 tpi . Recently my engine has been acting up for instance (i'm sure i spelled that wrong) when i turn my engine on my car starts puffing white smoke from the exhaust and it reeks of gasoline and i found that some semi dry gasoline at the end of my driver side manifold where the exhaust pipe connects to the manifold. I dont know where exactly its leaking gas. Prior to this added lucas injector cleaner about 2 weeks ago and it worked fine and i've done a recent tune up to the car about 1 month ago and changed the manifold gaskets, head gaskets, and injector O-rings. Also ive changed the charcoal canister and it still reeks like gasoline so i'm dumbfounded by this new problem my car is giving me so any answers would be appreciated thank you for your time.
Reply 0
May 8, 2012 | 12:14 AM
Re: i need help with my 305 tpi
white smoke, hows your coolant level? going down?, and check the color of your oil, if you changed o rings on injectors check for injector leaks, mine were leaking after i put new orings because i wasnt careful putting them back in.
Reply 0
May 8, 2012 | 06:29 AM
Sounds like a coolant leak/ poped headgasket to me.
Reply 0
Feb 20, 2013 | 04:11 PM
actually it was a blown head gasket thanks for the replies guys. But now engine got rebuilt and it wont even start. I've checked the plugs and wires but they are all connected right so right now i'm just lost i'll post a video of my car as soon as i can to see if you guys can help. Thanks
Reply 0
Feb 22, 2013 | 03:33 AM
Quote: actually it was a blown head gasket thanks for the replies guys. But now engine got rebuilt and it wont even start. I've checked the plugs and wires but they are all connected right so right now i'm just lost i'll post a video of my car as soon as i can to see if you guys can help. Thanks
Have you tried spraying starting fluid in while trying to start it?
Reply 0
Feb 22, 2013 | 04:06 PM
nope i havent i'll give it a try and see if it works
Reply 0
Feb 22, 2013 | 04:50 PM
ok so when i was gonna us the starting fluid i noticed that there was fuel in the throttle body im suspecting a bad sensor or my egr valve isnt working anymore so what do you guys think it is?
Reply 0
Feb 22, 2013 | 05:22 PM
Fuel PSI regulator could b bad.
Reply 0
Feb 23, 2013 | 03:56 PM
Quote: Have you tried spraying starting fluid in while trying to start it?
Ok so I used starting fluid still no luck but, although all it does is pop
Reply 0
Feb 23, 2013 | 04:00 PM
Quote: Fuel PSI regulator could b bad.
Well another guy it could be the fuel pressure diaphragm could be bad
Reply 0
Feb 23, 2013 | 04:15 PM
Yeah thats what I was meaning. pull the vac line off and look 4 raw fuel.
Reply 0
Feb 24, 2013 | 06:26 AM
Why are all these engines getting flooded with fuel lately?
If it did flood, then you spark plugs could've gotten wet, so you may need to either change them or pull them out and cook the tips with a propane torch to get the fuel out of the insulator.
Reply 0
Feb 24, 2013 | 10:35 AM
New fuels, old rubber not designed for the crappy new fuel in the regulators?
Reply 0
Feb 24, 2013 | 10:18 PM
Quote: New fuels, old rubber not designed for the crappy new fuel in the regulators?
You think they're going over 10% Ethanol now?
Reply 0
Feb 24, 2013 | 10:26 PM
Who knows, could just be old parts reaching the end of the line?
Reply 0
May 21, 2013 | 08:51 PM
Hey my 91 z28 with a 305 idles high and has no ***** off the line, what the hell could be causing this car to be such a dog? I've done a complete tune up, ported plenum, K&N air filter, 1.6 RR's, High flow cat and flowmaster exhaust. timing set at 6*, tried bumping but didn't do nothing, trans was rebuilt 2k miles ago, I'm changing the rear from the crap 2:73 to 3:42 or 3:73 as I type this.
I've owned a few of these cars and so far this one just sucks no matter what I do to it, I thought speed density was a good setup?
Reply 0
Subscribe
