New to tpi, not normal setup.
Old May 13, 2012 | 08:34 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Axle/Gears: GM 12 bolt/ 3.73
I have been doing a lot of research on here and other sites lately. Still kind of unsure what I need to use. My setup isn't in a Camaro its in a 67 C10 but this seems to be about the most knowledgeable site when it comes to TPI setup's.
I have a fresh rebuilt 307 that I have picked up a TPI setup for. The one I got is the speed density with the 7730 ecu (if I recall correctly). My goal is just a nice dependable DD with decent power and decent mpg. My questions are with the fuel injectors, egr system, VSS, and if I think of anything else I will add it.
My setup is as follows.
307 short block just rebuilt
305 HO 416 casting heads 52cc
Edelbrock 2102 cam, roller timing chain, hyd flat tappets
Comp Cams push rods
Headman long tubes
'90+ TPI setup
MSD dizzy and coil
Accell 8.8 wires
B&M Holeshot 2000 stall
Th350 with stage 1 shift kit
Afpr & rail mounted gauge
Efi high pressure inline fuel pump
With this setup I should be in the 9.5-9.8:1 comp range.
Here are the questions I have came up with.
1. Will my 19lb injectors be good for this setup or would I be better off with something along the 22lb mark? I don't have a HP goal in mind just don't want to run lean and have probs. I know if I go bigger I can back off my fuel pressure a bit or change the tuning on the prom. I do have a wide band I can tune by. I have some buddies that are mustang guys and knew I could get some of their 19lb Bosch III and run the normal 43.5psi rather than the 39psi and get approx 22lb. I just didn't know if it would be pushing them to hard. I do know the atomize better and would result in better mpg. If I don't need more than 19lb I cam just run them at 39psi. I have seen other with the same engine/head setup and sim cam break the 300 hp mark. Just don't know if that is where I will be.
2. EGR delete. Is if going to be ok to delete my EGR system and remove it from the prom? Would I be better off leaving it functional?
3. VSS. Since I have a TH350 and no VSS I have read that I can remove the VSS from my iron with no ill effects. Is this true?
4. O2 sensor placement. Since I am running long tube headers and true duals what's goin to be my best placement and options? I was figuring in my driver side collector with a heated O2. I know there I am only goin to be getting readings from half the engine but better than just in one runner.
I know about the vats I am either goin to remove it from the prom or get a simulator.
Thanks for the advice and help in advance.
Justin.
Old May 13, 2012 | 09:20 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: New to tpi, not normal setup.
since you dont' have to go through emission I would delete the code 32 and change the egr vs mat setting as well as the air. You are correct on a heated o2s that far down in the stream. I would install southbay fuel injectors bosch 3 19#hr. The vss would be a wise idea to install to help when you come to a stop to control the iac.
http://tpiparts.net/inc/sdetail/7587
http://www.southbayfuelinjectors.com...7&product=1500
Old May 13, 2012 | 10:15 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I will get that VSS. Will it run a aftermarket electronic speed-o for when I upgrade all my gauges?
I was thinking about just buying a .bin file for the prom. The only company I have been recomended to right now is pcmforless.com. They are wanting about $150 for the file with settings for cam, vats removed, EGR removed, and if I change injectors new coding for the injectors. I just haven't messed with any GM programming yet and I need it running soon so it looks lime I am goin to have to just buy a base map. I can always may another to play with and fine tune later on.
Is there anyone on here that would be good to get/buy a base map from?
Old May 15, 2012 | 08:26 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I know this is more of a matter of opinion but what would be the best sparkplugs for this setup? With having the tpi system, ecm, and MSD ign I am not sure what to run.
Old May 15, 2012 | 08:51 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I run nothing but NGK in mine and it runs great.
Old May 16, 2012 | 05:23 AM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I have always ran NGK in almost all of my Imports other than Europeans and I run Bosch in them. I wasn't sure which to run in this. What plug and temp?
Old May 18, 2012 | 09:56 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
What water neck/outlet would I use? The stock tpi onr is like half the size of my stock one and my radiator hose. What outlet would I need to get? I have thought about the aluminum swivel one but everyone I have talked to say they leak.
Not sure of it makes a diff but I have tall aluminum valve covers.
Old May 18, 2012 | 10:32 PM
Engine: Lb9
Transmission: M20
http://67-72chevytrucks.com/vboard/s...d.php?p=858564
Old May 18, 2012 | 10:43 PM
Mikey Millette's Avatar
Car: 1985 Trans Am
Engine: 305 H.O. Tuned Port Injection
Axle/Gears: 273
I have a 1985 TPI Trans Am and i need help with a wiring diagram because my fuel pump is strait wired and my mass air flow,fuel pump,and cooling fan relay pig tail are gone can any body help its a 305 H.O. heads PLEASE HELP It acually looks like they've cut the wires out of the wiring harness all i see is two thick orange wires that have to be hook up in order for it to run
Old May 18, 2012 | 10:44 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I didnt even think to check on there. I have a build thread on there.
Old May 18, 2012 | 10:45 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I know there wiring diagrams on here. I have downloaded them and have them on my phone. I can't tell you right off where they are.
Old May 18, 2012 | 10:59 PM
Engine: Lb9
Transmission: M20
Please don't hijack you can see them at gearheadefi or chevythunder.com or austinthirdgen
Old May 19, 2012 | 06:42 AM
subroc's Avatar
Engine: 355 TPI
Its been awhile since ive done them. I couldnt tell ya anymore unfortunately. Sorry.
Old May 19, 2012 | 08:34 AM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Chevythunder is where I seen them.
Old May 19, 2012 | 09:53 AM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I ordered that waterneck it won't be in til mid next week. Oreillys got it on they way. They only want $14 for it and pay for it when its picked up. As long as its the right one that solves my prob.
I have noticed some people have a air foil in their throttle body. Mine does not have this. Is it goin to make a diff at all not having it?
Old May 19, 2012 | 10:33 AM
Engine: Lb9
Transmission: M20
the claim is increase hp but my sensitive butt dyno can't tell a difference.
http://www.ebay.com/itm/C4-CORVETTE-...ht_3022wt_1063
Old May 19, 2012 | 05:08 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
My Bosch gen III 19lb injectors came in today and I made my EGR block off plate so I was able to get my intake on.
Here is where I have the motor to now. I need to get 4 lower runner bolts, 4 throttle body bolts, locking header bolts, alternator, aluminum power steering pulley, also have to make a custom CAI. I also think I am goin to get a new harmonic balancer cause mine do appear to be in the best of shape.
Old May 19, 2012 | 05:11 PM
Engine: Lb9
Transmission: M20
looks like your airfilter is off a ramjet 502
Old May 19, 2012 | 05:39 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
No clue it was with the tpi setup when I got it. I thought at first it was a K&N but its a GM Performance.
Old May 19, 2012 | 06:20 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Does anyone have a single Accell 8.8 spiral core rfi suppression wire laying around? One of mine has a bad spot on it and I don't really wanna spend $90 on a set over one wire. The one I need is 44" over all length with 90* plug boot.
Old May 19, 2012 | 06:25 PM
Engine: Lb9
Transmission: M20
yes it is a k&n made for gm performance 12490257 ramjet 502 same as the rc-5000, looks good
Old May 19, 2012 | 06:53 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I figured it was I cleaned it with my K&N recharger kit. I like how it looks but I want a cold air kit so I might have to get rid of it.
Old May 19, 2012 | 07:00 PM
Engine: Lb9
Transmission: M20
I will send you my address again when you done with it. lol
Old May 19, 2012 | 07:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Put a wanted here
https://www.thirdgen.org/forums/engi...pension-parts/
Old May 19, 2012 | 09:51 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Posted it up.
Old May 28, 2012 | 08:22 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Ok got another question.
What's the knock sensor I need? I wasn't sure if the 305 and the 350 sensors are the same or where to start looking for one at
Old May 28, 2012 | 08:50 PM
Engine: Lb9
Transmission: M20
I believe It a acdelco 213-91 gm#10456019 you need one for a 90-92 tpi 5.0L
Old May 31, 2012 | 11:36 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
What are the size of bolts that go into lower plenum. The longer ones that go into the bottom of the flange. I need bolt size, thread pitch, and length.
Old Jun 1, 2012 | 09:45 AM
Engine: Lb9
Transmission: M20
All the runner bolts are M8 x 1.25. You'll need three different lengths: 30mm, 40mm and 55mm
Old Jun 1, 2012 | 10:19 AM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I have all the runner bolts except the 4 long ones and the 4 throttle body ones. Well I have the 4 tb ones but I want them in stainless allen head
Old Jun 1, 2012 | 05:36 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Just thought I would post pics of the Lokar throttle cable and bracket for anyone interested in them.
I plan on making some brackets to hold the cable up above the runner using some SS clamps and the upper front and center bolts.
Old Jun 1, 2012 | 09:17 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Does anyone have a link to pics of the connectors and say what they go to with wiring colors?
Old Jun 3, 2012 | 12:15 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
I have no oil pressure sensor and the wiring just has 2 female spades crimped on. What sensor do I need? Is it just goin to be a universal sensor or a specific one with the tpi sensor? Also can I use this sensor for a aftermarket gauge?
Old Jun 3, 2012 | 12:46 PM
Engine: Lb9
Transmission: M20
acdelco PT2324
http://www.tpiparts.net/inc/sdetail/3995
http://www.hotrodlane.cc/newtech/tun...elcircuit.html
a C1804A may work gm 19190665 I just checked a switch and its a n/o switch until you get oil pressure, you would not connect the idiot light just the gray and orange.
this was a 85-87 corvette and camaro tpi oil pressure switch.
Old Jun 3, 2012 | 08:52 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Mine only has 2 wires though.
Old Jun 4, 2012 | 09:08 AM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
If you look at the link with the diagram I am missing the tan wire to the I/P. What is I/P? I am figuring its for the idiot light but not sure.
Old Jun 4, 2012 | 09:45 AM
Engine: Lb9
Transmission: M20
I/p Is instrument panel the ground side of the low oil pressure switch idiot light.
Old Jun 4, 2012 | 12:22 PM
WORP67's Avatar
Car: 67 Chevy C10
Engine: 307 TPI
Transmission: Th350
Ok cool thanks thats what I thought. I won't need that anyways cause of my setup.
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
destroyerwes
Aug 26, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
