EGR Solenoid from Rick's Camaro
Old May 14, 2012 | 01:28 PM
TheJoeY88's Avatar
Has anyone ever used the EGR Solenoid from Rick's Camaro?
http://www.rickscamaros.com/camaro-s...1985-1992.html
was wondering if it works on the TPI cars.
Old May 14, 2012 | 10:50 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: EGR Solenoid from Rick's Camaro
Hello TheJoeY88!!
Check your PM!!!
Old May 15, 2012 | 12:46 AM
kylet8020's Avatar
Car: 88 iroc
Engine: 305 tpi
Transmission: unknown atm
Axle/Gears: unknown atm
Originally Posted by 87IROC-DAN61
Hello TheJoeY88!!
Check your PM!!!
Hell don't hide good knowledge if It's good say it if It's the other side of the coin let us know so we don't buy it
Old May 15, 2012 | 01:44 AM
Hello kylet8020!!
I was just waiting to see if anybody else came up with anything, however, I see that isn't so!!!
To let the "cat out of the bag", I can't tell you if it's good or not, when I e-mailed Ricks Camaro about the part, they told me it was good for TPI cars, however when TheJoeY88 called them, they told him it was for TBI cars!!!
Two inquirys, two different answers!!!
Always a "grey" area, never black and white!!!!
Old May 17, 2012 | 09:07 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
To be honest, I can't imagine why it wouldn't work. The solenoid just opens and closes a vacuum port. Unless the mounting configuration is vastly different, I can't see why they'd be different at all.
Old May 20, 2012 | 11:56 PM
Hello Jim85IROC!!
I thought that was the case also, however in the thread "EGR solenoid discontinued" I had stated the same as you have just done, but it appears that the ones who have actually tried it, say that's not the case!!
Take the EGR solenoid from the LT1, it apparently doesn't work on the TPI motors, even though it looks the same except for the bracket!!
The only thing that I can think of that might be different is the coil windings of the solenoid, affecting the duty cycle, and that's really stretching it!!
As you have said, it just opens and closes a vaccum port!!
jklein337
Sep 19, 2018 06:23 PM
fasteddi
Sep 2, 2015 10:29 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
mdtoren
Aug 16, 2015 05:45 PM
