Cam and spring question, would appreciate the help!
Old May 20, 2012 | 09:47 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
looking to install an lt1 cam in my camaro with an 89 TPI 305 lb9, I know some different years in the lt1 cams had different specs, some small differences whats the best year if any? and I want to change my Valve springs as well, should I buy valve springs for a 350 lt1 and put them on my 305 lb9 heads or stock TPI Lb9 springs.
Old May 22, 2012 | 02:32 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Re: Cam and spring question, would appreciate the help!
anything??
Old May 22, 2012 | 09:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Cheapest GM LT1 springs are the Hotcam /ZZ4 springs @ $36
http://sdparts.com/details/gm-perfor...parts/12495494
You need a 305 expert to say whether they are a drop in fit on your 305 heads like they are on LT1 / 113 heads
Old May 22, 2012 | 09:16 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
lb9 and iron l98 heads should take the same spring...
Old May 22, 2012 | 11:15 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Stock lb9 heads with an lt1 cam, what springs with that combo
Old May 24, 2012 | 10:27 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Do i go stock lb9 springs or stock lt1 springs that all i was wondering
Old May 25, 2012 | 08:19 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
here is the 94-95 LT1 cam specs
Duration: INT.205/EXT.207
Lift 1.5 RR 447/459
Lift 1.6 RR 477/490
LSA 117
If you use 1.5 ratio rockers your still at or a little above the max. If I where you I would use an aftermarket valve spring and go with 1.6 ratio rockers to get that much more out of it.
I do not know if stock LT1 spring will work on 305 heads. If I were you I would place a phone call to a few local performance shops that do LT1 and TPI cars and get thier opinion. Chances are if it can be done they have done it. I distinkly remember LT1 cars complaining about weak valve springs though so you may want to go another way with the springs
EDIT: here is the link to the page I got the cam specs from http://www.ws6.com/faq/4_2.htm#ch4_2aw
Old May 28, 2012 | 09:50 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
I was just thinking of going with stock 350 l98 springs brand new and the lt1 cam, i dont want to go 1.6 rockers
Old May 29, 2012 | 07:51 AM
Car: 91 Trans Am
Engine: 355 TPI
I have a set of valve springs, roller lifters and a used LT1 cam that has already been modified for small block use. I also have a stock vortec 350 cam
Old Sep 26, 2012 | 11:43 AM
SLPGTA's Avatar
Car: 1990 Trans Am GTA
Transmission: T5, 5 speed
Is this setup still for sale?
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
