Ignition Promblem! Car Starts Fine But After A Minute The Idle Goes Retarded
Old May 29, 2012 | 07:09 PM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
Yesterday When I Went To Turn On My Car It Started Up And Was Running Fine But After About 2 Minutes The Idle Got Really Sloppy, Started Backfiring And The Car Died A Few Times As I Was Driving Back Home. It Started Right Back Up Each Time After It Died But The Idle Was Still Running Sloppy, I Let It Cool Off For About 2 Hours & Disconnected The Battery Then I Reconnceted It & Let It Sit For 20 Minutes And Started It. Its Started Up & Ran Fine For The 1st Couple Minutes Then The Cycle Repeated. Does This Problem Sound Familiar To Anyone? I'm Wondering Which Sensors Could Cause That & Could The Ignition Conttole Module Be The Problem? Just Replaced It A Year Ago But Autozone Parts Ain't All That HaHa
Old May 29, 2012 | 10:42 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Ignition Promblem! Car Starts Fine But After A Minute The Idle Goes Retarded
My first guess would be the iac valve. There are other things, but i think this is most likely the culprit. Have you checked anything?
Old May 30, 2012 | 12:16 AM
Car: 1986 Camaro
Axle/Gears: 411
Thanks for the reply, yeah i checked the ignition control module & the vacum hoses, I seen in the hand book it says to check the PVC system & also the Knock Sensor so i will check those 2 tomorrow morning. Sorry if this sounds like a dumb question but what is the IAC Valve & where is it located?
Old May 30, 2012 | 11:30 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
It's the Idle Air Control valve and controls the amount of air into the engine when you're at idle. It's located on the bottom of the throttle body kinda on the passenger side. Over time it tend to get clogged up with junk and needs to be removed and cleaned.
It could also be a bad O2 sensor. Sounds like it's something when the car goes into closed loop.
Old May 30, 2012 | 09:17 PM
Car: 1986 Camaro
Axle/Gears: 411
Oh Ok It Wouldn't Happen To Be That Squarish 4 Plug Sensor On The Bottom Of The Throttlebody Would It? Yeah I Hit All My Sensors Around The Intake With Sensor Cleaner But I'm Thinking One Of Them Just Went Bad, Also I Heard It Could Be The Knock Sesnor. My Car Runs Fine When I Start It But It Seems After A Minute It Goes To **** & Turns Off So Yeah Pretty Much When It Heats Up A Little & Goes Into Closed Loop
Old May 31, 2012 | 07:46 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
Yes, that's the one. You might want to pull it out to clean it, but I don't think that's your problem. I'd guess it's the O2 sensor, but I guess the knock sensor is a possiblity as well. Be prepared when you remove the knock sensor as it goes into the water jacket and will make a bit of a mess when you remove it.
Old May 31, 2012 | 11:57 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Check the fuel pressure regulator. It may have went bad.
Wade787b
Sep 29, 2015 01:15 PM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
