Cars running Horribly again!
Old 07-02-2012, 01:26 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Well I have a 89 GTA with a 350 TPI, i recently replaced the injectors and it ran great for a few days and then out of no where it started running like poop again. Im going to check the TPS Sensor but if it isnt that i have no idea where else to go, any suggestions. The car starts idles like crap, wont rev up and in general just runs like complete ****. Please any suggestions or ideas if you need to know anything more just ask. HELP!!!!!!!
Old 07-02-2012, 02:19 PM
84ws689bird's Avatar
Car: 1988 IROC
Engine: 5.7
Axle/Gears: 2.77 posi
Re: Cars running Horribly again!
Just recently had the same symptoms with my IROC, turned out it was the MAF sensor, MAF sensor relay AND the burnoff sensor relay. total cost, doing it myself, was around $220 pictures of relays and sensor below.
http://s662.photobucket.com/albums/u...ent=relays.jpg
Old 07-02-2012, 02:25 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
i replaced the maf already how did you know those relays where bad?
Old 07-04-2012, 01:52 AM
Car: 1988 IROC
Engine: 5.7
my mechanic/buddy is a GM master tech AND a third gen owner, lol, he said they generally go bad at the same time as the MAF
Old 07-04-2012, 02:13 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
take your intake plumbing off and spray throttle body cleaner in the intake, these cars are bad about carbon build up. Just follow the directions on the can.
Old 07-04-2012, 05:47 AM
9340Ruby's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 pos
Check your fuel pressure on the rails to see what you have when you first turn the key. I am not sure of the specs but that would be a great start. Fuel starvation will definitely make these motors run terrible.
Old 07-04-2012, 09:52 AM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Well out of no where i got a vats code so im putting a bypass in and then im going to replace the computer to eliminate that problem. Than im going to check fuel pressure and it cant be carbon buildup becuase i actually pulled the entire tpi system off and soaked it in simple green to break down all the carbon.
midge54
12-27-2019 04:14 PM
Azrael91966669
25
06-20-2017 04:04 AM
kyleb24
08-15-2015 08:24 AM
Kaweh
08-09-2015 02:54 PM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: Cars running Horribly again!
