fuel pump.... where to cut
Old Sep 3, 2012 | 09:28 AM
poordo's Avatar
Car: 1986 Trans Am
I'm wanting to switch my fuel pump and I dont want to drop the tank .... do I cut out here to get to it? And is this the wires for the pump?
Old Sep 3, 2012 | 09:36 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: fuel pump.... where to cut
If you had used the Search feature here on TGO, you'd find threads all about cutting the access door like:
https://www.thirdgen.org/forums/faq-...tal-above.html
https://www.thirdgen.org/forums/tpi/...cces-done.html
https://www.thirdgen.org/forums/post...4-post160.html
Old Sep 3, 2012 | 09:51 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Old Sep 3, 2012 | 10:35 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Seek and you will find;http://www.mifbody.com/vbulletin/sho...res-and-How-To
Old Sep 3, 2012 | 03:20 PM
Car: GTA
Originally Posted by red rock
Sorry but that is a bad link, as in.....It is for a 4th gen so it doesn't fully address the OPs 3rd gen.
Which means that whole the hole cutting is the same....4th gens do not have to deal with cutting their lines because there are disconnects at the top of the tank.
So your link is basically not a complete write up for the OPs car which is a 3rd gen. I already posted TGO links above that actually address his issue, so what was the point in you posting your only partially addressing the mod link?
Old Sep 3, 2012 | 04:16 PM
red rock's Avatar
Car: 1987 iroc
The op was questioning cutting a hole, the point is the same, you cut a hole to access the fuel pump and seal it. your post's revealed cutting a hole and sealing it. The one i showed using a grinder, some use a tin snip, maybe getting idea's is not such a bad thing after all.
Old Sep 3, 2012 | 05:04 PM
Car: GTA
You obviously did not read my links, because they DO address having to cut the fuel lines & reattaching them with more than just hose & clamps.
Your link implies that he can simply cut the floor & disconnect the lines. Boy he woulda been frustrated when he got in there & found out the truth.
Please provide full truths when giving people advice, not just part of it. Or are you the kind of guy that would tell a guy to remove the 5 lug nuts to get a wheel off, but leave out the part about having to jack the car up?
Old Sep 3, 2012 | 06:17 PM
red rock's Avatar
Car: 1987 iroc
You need to take a chill pill, this site is here for all to contribute. Some of you on here are a little up tight. I'm sure he'll read your post first, I just added a link to show what a nice job it could be if done right. You know, there are some that don't agree with cutting it at all. My point was, if your going to do it, do it right. Now you don't need to be ripen on some one for adding a link, even if it was a fourth gen gas pump. The job looked good when finished. So, if you have a need for the last word, go ahead.
Old Sep 3, 2012 | 06:19 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
What says the car doesnt already have a 4th gen tank ?
Old Sep 3, 2012 | 07:22 PM
Car: GTA
Unsubscribed!
Old Sep 3, 2012 | 07:30 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Oh no, master of the hole hacking has unsubscribed, now how will people find out how to hack holes into cars instead of doing it the right way.
Old Sep 3, 2012 | 10:35 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Seems to me it would be a lot easier and quicker to drop the tank than to cut a hole in the floor of the car, cut the fuel lines, dig up compression fittings and extra lengths of hard lines, make a hole cover, paint, etc.
No I didn't read the links but I am familiar with the hole cutting process and yes, I have dropped the tank a few times.
Old Sep 3, 2012 | 10:42 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
It is faster, 45 minutes I can have the pump in my hand, people cant seem to grasp that not only is it something you shouldnt be changing often, at all, but that it also can weaken the car, all for how much actual time saved ?
Old Sep 3, 2012 | 11:37 PM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
It is much simpler to do it right than to do all that is involved in cutting a hole. It's just very intimidating to someone who has never done it. Cutting a hole to get to something just an inch away on the other side appears so much easier. It's not!
Old Sep 4, 2012 | 12:26 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
It doesn't take that much longer to drop the rear differential, Drop your exhaust and drop the tank.. I recently did mine in 5 hours out and in.. Of couse, I have done alot of work to my car and all the bolts are in perfect shape.. I would recommend the same thing, to do it right way instead of cutting holes in the body.
Old Sep 4, 2012 | 11:34 AM
poordo's Avatar
Car: 1986 Trans Am
Wasn't intentionally trying to start a cat fight but I got it out switched and sealed back up.... took about an hour.... I dont have a $500,000 garage so that was much quicker than trying to drop everything.
Old Sep 4, 2012 | 03:35 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Weird that in a driveway with a few basic tools it can be out in 45 minutes.
Old Sep 4, 2012 | 04:17 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
poordo, did you get some pics while you were cutting and changing for the next guy wanting to do the samething???
Old Sep 4, 2012 | 06:54 PM
poordo's Avatar
Car: 1986 Trans Am
Yes I did I will post some shortly
Old Jun 1, 2015 | 07:48 AM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
when will you post those.
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
TA8487
Aug 11, 2015 09:02 PM
