Replacing intake manifold gaskets. Fuel rail??
Old Sep 27, 2012 | 06:38 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
I'm stuck. Do I need to remove the fuel rail to take off my intake? Car is already torn apart so idk how I'd depressurize the system
Old Sep 27, 2012 | 07:14 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
Re: Replacing intake manifold gaskets. Fuel rail??
to depressurize the system just pop the gas cap off,thats all I did.I just recently rebuilt my TPI motor and when taking it all apart I didn't remove the fuel rail.Just unhook the fuel lines and take the intake bolts out.But I would suggest doing it just to check out the injectors.
and its much easier to get to the center bolts on the intake with it out of the way...Hope this helps..If I've misled you in any way I'm truly sorry.
Old Sep 27, 2012 | 07:19 PM
Engine: 350 L98/LS2
It helps, thank you very much
Andrew6.688
Dec 13, 2015 10:59 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
92projectcamaro
Aug 6, 2015 01:20 PM
