lb9 cam help
Old Oct 1, 2012 | 08:47 AM
xcorvettekid06x's Avatar
Car: 1991 Camaro RS
lb9 cam help
So me and my buddy are putting a stock 85 lb9 into his 85 iroc but i have a cam laying around my house i was wondering if i could put in there stock. i was told it is a stock corvette 350 cam. i think its a 79 l82 cam. would this work stock?
Old Oct 1, 2012 | 11:49 AM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Re: lb9 cam help
Yeah it should work. Although any time you change the cam you should consider getting a custom chip for your application.
The 1985 LB9's are unique because that cam is patterned after the L69 cam - which itself was patterned after the Corvette L82 cam.
GM 1985 LB9 Cam specs:
Part Number: 14093643
Cam specs: Lobe separation angle 114.5 degrees
Cam specs: 0.404 intake / 0.415 exhaust with 1.5 ratio rocker arms
https://www.thirdgen.org/1985-chevy-camaro
The GM Performance Parts 290hp crate 350 has the same cam that came in the L82 originally I think.
Cam Part Number: 3896962
Cam specs: 222 degree intake / 222 degree exhaust
Cam specs: 0.450 intake / 0.460 exhaust with 1.5 ratio rocker arms.
http://www.chevroletperformance.com/...P&sku=12499529
Old Oct 2, 2012 | 08:39 AM
APACHE JOHN's Avatar
Car: 1991 Z28
Engine: 350 TPI RAMJET COMING
Re: lb9 cam help
L69 AND 1985 LB9 cam are the same........same as the L81 Corvette Camshaft (1981 350 carb) not the L82 which has more duration.
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
