TPS Reading Backwards . . .
Old Oct 8, 2012 | 10:06 PM
Copperhead's Avatar
So in the ongoing saga I now have everything screwed together and ready to fire. However, my last steps were to install a battery, test everything, set the TPS, and go. However, the TPS I have (unknown origin, it was on the BBK throttel body when I got it used) reads ~4.5V at closed throttle, going to ~0.5V at WOT - - the reverse of what it should be.
Are there TPS's that read backwards to ours? Should I just grab a new one? Or could it be something else?
Old Oct 8, 2012 | 10:41 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPS Reading Backwards . . .
if the read back of the potentiometer is backwards out of the center of the tps the 5v ref and ground are swapped. if the tps feed back is a little over 4v while cranking injector pulse will stop the ecm will be in clear flood mode.
Old Oct 8, 2012 | 10:43 PM
Copperhead's Avatar
So what color/voltage wires should go to top, center, bottom???
Old Oct 8, 2012 | 10:56 PM
Engine: Lb9
Transmission: M20
the top wire is black ground, center wire is blue feedback to the ecm, the bottom is grey 5v ref from ecm.
Old Oct 8, 2012 | 11:20 PM
Copperhead's Avatar
You were exactly right, tunedperformanc, all is good now. Thanks!
Old Oct 9, 2012 | 08:06 AM
Engine: Lb9
Transmission: M20
glad too help
J-money
Jan 4, 2019 09:45 AM
TBRays98
Sep 6, 2015 05:05 PM
FormulasOnly
Sep 6, 2015 10:42 AM
scotrans am
Sep 5, 2015 04:26 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
