Intake gasket material
Old Oct 11, 2012 | 10:09 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
As the title suggests, what is the material used to make intake gaskets(runners, tb), and what do you recommend? I need to make sure custom ones and want to get a sheet to do so. A quick search online gave me a Mr. Gaskets gasket sheet. The link is below:
http://www.summitracing.com/parts/MRG-77B/
If I am not mistaken this material is similar (if not the same) as the one used for oil pan gaskets. Would this be suitable for the intake? Thanks
Old Oct 19, 2012 | 08:43 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Re: Intake gasket material
Anyone?
Old Oct 19, 2012 | 09:13 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I believe I used something similar, only from Fel-Pro. I actually just went down to AutoZone and bought it there. They had a couple different thicknesses and it's easier to decide when you can see and touch it. The runners and TB should be able to use a very standard type gasket material.
To make the gaskets (I made my own when I siamesed my runners) I made an outline of the part and cut the gasket with a razor. I then use a small hammer to tap on the gasket while it was sitting on the part. This made an outline of the exact shape I needed.
Old Oct 19, 2012 | 09:21 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
That is exactly what I need the material for. I have siamesed a pair of runners and need a new gasket to make it work. Are there any issues with using this type of material for intake gaskets? I know the stock ones have the metal mesh within them, but I think this is for strength more than anything else.
Old Oct 20, 2012 | 01:52 AM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
I have siamesed runners and base, had to make my own gaskets out of previously mentioned gasket paper. Had no problems with it though. Couldn't help you out as to what brand/material to get though, everything I used was free to me lol.
Old Oct 26, 2012 | 10:18 PM
89L98TPI's Avatar
Car: 89 Corvette
I have a Super Ram on my Vette. the gaskets for the Super Ram have no metal lining in them so I figure you'll be OK. I also thought of making my own. Its $50 for a set for me.
Posted from Thirdgen.org App for Android
Old Oct 27, 2012 | 01:17 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
cereal box.
Old Oct 27, 2012 | 07:22 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Originally Posted by Jim85IROC
cereal box.
I want to thnk you are joking, but on the other hand I am curious......Have any pics?
Old Oct 27, 2012 | 09:06 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
cereal box.
No water, no oil, no pressure. Sure, why not.
Old Oct 28, 2012 | 01:55 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Call SCE gaskets in Santa Clarita ca get yourself some real gasket material. Dont halfazz it
All differnt thicknesses/materials. They will get you what you need.
Aaron Hunter
Sales Manager
SPM Gaskets, LLC.
712-262-9313
SCE Gaskets Inc.
661-728-9200
scegaskets.com
Old Oct 28, 2012 | 03:04 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Or, you could just walk into any auto parts store and order the correct gaskets, complete with the plastic locator nipples. Part # is Fel-Pro MS93160:
http://www.rockauto.com/catalog/more...365&cc=1035728
Old Oct 30, 2012 | 07:25 AM
Jim85IROC's Avatar
I haven't done it, but others here have. Like eseibel67 mentioned, there's not really too much that will cause a problem with the gaskets.
While most of us (myself included) wouldn't ever use a cereal box for any sort of permanent installation, it certainly can be used in a pinch, and even for a permanent situation, any similar cardboard stock can be used instead of paying more money for gasket material that's not going to be any better.
Old Oct 30, 2012 | 07:57 AM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Interesting. I want to do a couple tests with different runners on my car. This may fit the bill for a temp solution instead of making and wasting gasket material between changes.
Old Oct 30, 2012 | 09:07 AM
Axle/Gears: 4.11
No offense this is a new low in car repair LOL.
Geez guys....
1992 Trans Am
May 10, 2023 07:19 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Wife'sCar
Sep 5, 2015 08:58 AM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
