fuel pump.(not getting any pressure)
Old Oct 12, 2012 | 09:48 PM
RestLess92's Avatar
Car: 89 Z28 T-Top
Axle/Gears: 3.27 posi
... i have a 87 l98 5.7 camaro, i bought it off some guy that had it under a tree in his backyard all mest up.. well at first i was getting 35lbs on fuel release pressure gauge, so i replaced the fuel pump because i thought it was too low & was also told by NAPA auto parts that minimum should 70-100lbs. now i dont have any pressure at all. and cant seem to find the problem to it.. i do get spark, i replaced fuel relay, rechecked pump, replaced fuel filter.. i was told there are two wires that should go to possitive on battery for injector to turn on but i do not know which ones they are.. i do not know what else i can do to it inorder for me to get my fuel to come back up. any help would be helpful thanks
Old Oct 13, 2012 | 01:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pump.(not getting any pressure)
Originally Posted by RestLess92
. told by NAPA auto parts that minimum should 70-100lbs.
Should be around 45 psi (43.5 @ idle with reg vac line disconnected )
i replaced the fuel pump now i dont have any pressure at all. and cant seem to find the problem to it..
Have you confirmed the new pump is actually running?
Do you have any fuel flow at the engine?
Old Oct 13, 2012 | 01:59 AM
RestLess92's Avatar
Car: 89 Z28 T-Top
I actually just finished taking it down again right now. It turns on once with the first turn on ignition switch after that it doesnt make any noise once i click ignition back and forth..
Old Oct 13, 2012 | 03:07 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Exactly as it should;
the computer only turns it on for 2 sec to prime the system then turns it off until you crank the engine over
Pressure should hold and leak down slowly but even if it drops to zero should it come back up again as soon as you crank over
Do you have pressure when cranking the engine over? (How much)
Old Oct 13, 2012 | 03:20 AM
RestLess92's Avatar
Car: 89 Z28 T-Top
45psi, i put old pump back on.. Now i have pressure but still doesnt not turn on unless i spray some starting fluid.. Relay is good..
Old Oct 13, 2012 | 08:38 AM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
whip out the volt meter and ohm out the injectors, should be in the 14-18 ohm range to be good
Old Oct 13, 2012 | 09:41 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
still doesnt not turn on unless i spray some starting fluid...
Does it stay running?
Relay is good..
Might be but if it is not being operated by the computer then you still have a problem
Old Oct 13, 2012 | 10:57 PM
RestLess92's Avatar
Car: 89 Z28 T-Top
no it turns off..
how would i know if its being operated or not
Old Oct 13, 2012 | 11:30 PM
RestLess92's Avatar
Car: 89 Z28 T-Top
just tested the injector connector and it does NOT have any power.. why would this be?
Old Oct 13, 2012 | 11:58 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Check the injector fuses
Should have 12V on one side of the injector plug ; key on
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
