Roller Rockers
Old Oct 23, 2012 | 10:02 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
Roller Rockers
I'm getting a crate L98 for my car soon. I don't want big power, but I want to keep it pretty close to stock. So far i'll be running a custom tune, AS&M runners, edlebrock base (all port matched), stock throttle body, and Dyno Don headers with a dual cat exhaust. Would 1.6 ratio roller rockers add anything to this set up? Would they interfere with anything? I've heard they are noisier and can lead to false knock.
Old Oct 23, 2012 | 11:12 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Roller Rockers
They make self aligning rockers that fit under stock valve covers, they are narrower. If you are going stock but want all the stock you can get then look at 1.6 rockers and a zz4 cam. You can install a zz4 cam and it will run fine on a stock chip with no tuning. I ran one for years in my 89 350 iroc and it would out run an lt1 car. Thats what I am putting in my vert is a 350 with steel gm 1pc crank, 6 inch H beam rods with forged Mahle pistons (slightly dished) balanced. Probably going to get the ported pro comps.
Old Oct 23, 2012 | 11:15 PM
actarnoff's Avatar
Engine: 355 TPI
Re: Roller Rockers
Any word on if the ZZ4 cam will pass emissions? I'm in the PRK (people's republic of kalifornia)
Old Oct 24, 2012 | 01:12 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Roller Rockers
u need to change the springs if going with that cam,especially with 1.6 rockers! maximum lift on stock springs is only like .470"
Old Oct 25, 2012 | 02:53 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Roller Rockers
Where are you getting the crate motor? I have an L98 in my 91Z that is getting tired. Trying to figure out if I should do the valve seals-they are leaking- or pull the whole motor...
Old Oct 25, 2012 | 04:22 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
i wouldn't worry about valve seals,does it smoke a little upon startup?
Old Oct 25, 2012 | 04:23 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
1.6 rockers only work w/ stock cam specs, add a big cam and u better beef up the springs
Old Oct 25, 2012 | 05:14 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: Roller Rockers
All I gotta say is if your gonna get roller rockers, you still have to fix the geometry or you will destroy your engine if the valve train fails. ALso you need narrow body roller rockers or the stock stud guides on the valve cover will hit the rr and the valve cover will not mount flush. best narrow body rr are the CompCams self aligning Magnum RR's.... Picture of the magnums are below...
Another narrow body rr is the Scorpion RR below......
Not EVERYBODY will tell you about the "geometry" of the valve train. So if you wanna learn more about fixing the "geometry" of the valvetrain, here is the link.
http://www.compcams.com/Products/CC-...rods%27-0.aspx
http://www.pontiacstreetperformance....traingeom.html
http://www.carcraft.com/techarticles...h/viewall.html
Old Oct 25, 2012 | 05:58 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
narrow body,self alligning
Old Oct 26, 2012 | 10:11 PM
89L98TPI's Avatar
Car: 89 Corvette
I'm selling a set of Comp Cams Hi-tec stainless 1.6 RR right now on corvetteforum. I'm new here so I don't have my privileges to sell yet. let me know if your interested
Posted from Thirdgen.org App for Android
Old Oct 26, 2012 | 11:10 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
they will give a slightly throatier exhaust note too
Old Oct 29, 2012 | 12:52 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Roller Rockers
Not to hijack the thread, but I HAVE to do the seals: it smokes A LOT on startup and I am oiling at least 2 plugs and dropping cylinders.
While I am doing it, given that the engine is bone stock, is replacing the springs and upgrading rockers worth the expense- what type do you guys recommend and why? I would be happy to get back the horsepower that 21 years of driving and 194,000 miles have robbed from her!
Old Oct 29, 2012 | 01:14 AM
Re: Roller Rockers
I already mentioned which rockers are best for the centerbolt valve covers. You have to investigate which valve springs can take the maximum a given ratio is applied (1.5 or 1.6 rr) before the springs begin to bind.
Old Oct 29, 2012 | 02:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Roller Rockers
What heads?
Going to want a good TPI setup to use /need .544 lift on the exh ( ZZ4 exh = .510 lift w/ 1.5's ) as well as some good valve springs.
The GMPP ZZ4/LT4 springs that go with the cam are good for .525
Old Oct 29, 2012 | 11:48 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
I don't think you should be losing any hp from time.
Old Oct 29, 2012 | 04:19 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Roller Rockers
I suspect new seals are not going to solve your oiling problem
@ 200K your rings are probably on the way out ( if not already gone on the cylinders with oily plugs ) and the majority of the oil in the cylinder is coming up past the rings;
not down from the valve seals
Once you loose the piston ring seal you loose compression so you are then down on horse power and it just slowly gets worse until the engine dies
Old Oct 29, 2012 | 05:27 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Roller Rockers
I dissagree: these engines are notorious for leaking valve seals. If I was getting oil blowby, I would be burning it while the engine is running. I only get oil smoke on startup, not while it is running. Also, the plugs show wet oil coating if they are pulled after letting it sit and cool. That oil is coming down, not up...
Old Oct 29, 2012 | 05:34 PM
Re: Roller Rockers
These engines are notorious only IF the owners or PO never did an over haul. Any vehicle the has the similar style valve seals are and will leak if not replaced or maintained like how they should be. You gotta remember, you are focused on these f-bodies because you own one, but fail to realize that this occurs on a good percentage of cars of the 90's era.
Old Oct 29, 2012 | 05:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Roller Rockers
I dissagree: If I was getting oil blowby, I would be burning it while the engine is running.
Whatever
these engines are notorious for leaking valve seals. ...
Is asking a bit much for them to still perform as new
Especially given your engine is 20 years old and has 200K on the clock , possibly will the valve seals it originally left the factory with
Old Oct 29, 2012 | 06:32 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Re: Roller Rockers
i would take vettoz words so far hi has not pointed me wrong this guy gets my a++++
hope you ok with me saying something vettoz
Old Oct 29, 2012 | 06:58 PM
Re: Roller Rockers
Vetteoz knows his stuff. Unfortunately for me, my advice goes poof as no has mentioned, "hey, Chevy86 has a point about the geometry of the valve train". I'm out.
Old Oct 29, 2012 | 07:00 PM
Re: Roller Rockers
Good luck actornoff. PS, I was born in Huntington Park. Big ups to the City of The Angels.
Old Oct 29, 2012 | 07:15 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
its just your valve seals if it does it on startup. No big deal
Old Oct 29, 2012 | 09:48 PM
Abubaca's Avatar
Re: Roller Rockers
There's no need for 1.6 rr on a stock cam, and if you DO change the cam, most are spec'd with 1.5s. You can simply choose the appropriate cam specs without going 1.6.
....and even the zz4 cam gets a little on the big side for a LTR TPI with 1.6 rockers.
Old Oct 29, 2012 | 09:53 PM
actarnoff's Avatar
Engine: 355 TPI
Re: Roller Rockers
So there is zero benefit? Even just to free up friction in the valve train?
Old Oct 29, 2012 | 11:45 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
you will gain a few hp, and the exhaust note will be a bit more throaty due to the increased lift. Your engine will probably last longer too.
Old Oct 30, 2012 | 12:03 AM
Abubaca's Avatar
Re: Roller Rockers
My point was simply addressing the lift difference. ...and I would say no. No benefit that you'll ever see. Obviously you're increasing lift, hence air in and out, and the dyno may see a difference, but the benefit of a PLANNED out engine cannot be overstated. Adding .1" of lift because your uncle's neighbor had a spare set of 1.6's sitting int he toolbox just isn't gonna make a worthwhile difference.
....now the fact that you're adding rollers and roller tips certainly helps. Also, stamped stock rockers can flex as much as .2" so a good quality set of rockers is a great addition. .....but pick your ratio and cam first. Then buy a good set of whatever ratio rockers you determined you needed. Anything you can buy in 1.6, you can buy in 1.5.
Old Oct 30, 2012 | 12:17 AM
Abubaca's Avatar
Re: Roller Rockers
As for your combo, if you're limited on cash, get your motor in, as close to stock as you can, (exhaust is still a must-do however) and put the money into a torque converter. If you're running stock L98 heads, no cam, and no intake will come close to what you'll feel from a better converter.
.......but speaking just about the engine, assuming you're keeping the heads stock, a cam similar to the zz4 cam would certainly help. There are several good cams with similar specs. My zz4 cam passed (barely) in NC. I doubt it would pass CA. ...I did run a stock tune at the time (on a stock 89/MAF set up). You'll want the LT4 or comparable springs, and screw in studs too, although so far I've survived with press-ins. With that pretty mild set up, a good set of low cost (not cheap) roller tip rockers would be plenty. Remember, there are TONS of multi-hundred thousand mile small blocks still running stock stamped rockers. If ya spend 6 grand on a motor, what's a couple hundred more for full rollers. If you're just putting a stock replacement back in, ya gotta ask where's your money gonna get you the most return.
Old Oct 30, 2012 | 12:36 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Roller Rockers
Whatever. Seriously? 'Is this the 5 minute arguement, or the full half hour?' I am not looking for a fight- just the input of someone with no axe to grind. Correct the following if I have it wrong:
1) Gen 1 SBCs are prone to valve seal failure over time.
2) if it blows oil smoke on startup, the consensus in the SBC community is 'valve seals'.
3) if it blows oil consistently during operation, it could be rings.
4) if it fails a 'leak down test' it could be rings.
Mine a) blows smoke on start up, b) doesn't blow oil smoke during regular operation, c) is fouling plugs with what looks like oil, d) I am getting a 'code 43':
Do you think if the valve seals are leaking, it will cause the computer to show a 'code 43'?
Don't think that is too hard a question... 'yes', 'no', or 'I don't know'.
Old Oct 30, 2012 | 12:39 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
Code 43 is a knock sensor. Make sure the connector didnt come unplugged too.Yes, I would say you are correct with statements 2-4
Old Oct 30, 2012 | 01:06 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Roller Rockers
Thanks ninetyone!
Old Oct 30, 2012 | 05:05 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Roller Rockers
Found a broken knock sensor lead! Anyone know how to test the sensor while I am at it?
Old Oct 30, 2012 | 05:27 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Roller Rockers
Should meter out at 3300 - 4500 OHMS
Should have 4 - 6 volts on the supply wire with key on
Old Oct 30, 2012 | 08:00 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
You can test if it is working too ,by tapping softly with a wrench near the sensor. It should retard the timing. You will need to reconnect it first tho.
Old Oct 30, 2012 | 08:14 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: Roller Rockers
With 194K your guides are probably loose. Seals alone may not help.
Old Oct 30, 2012 | 09:07 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Roller Rockers
True.
Also True.
If your going to remove all the stock rockers ANYWAY,..... install some RR's while your in there. I always add 1.6 rockers to every head I have to tear down when keeping a stock Cam. 1.6 opens the valve a bit more, reduce friction/heat & add a few ponies for cheap $$.
http://www.ehow.com/list_6730063_ben...-rockers_.html
,....... The Corvette Club Grand Sport Registry ran unbiased side-by-side comparisons of a Chevrolet LT1 and LT4 engine. Even though both engines have the same 350-cubic-inch displacement, the LT4 produces more horsepower. Grand Sport Registry attributes part of the increased horsepower to roller rockers. By reducing friction in the LT4 over the conventional rocker arms used in the LT1, more horsepower is available to the wheels. Furthermore, Grand Sport Registry took both engines apart, and discovered galling (direct metal-to-metal contact caused by oil starvation) on the conventional rocker arms.
If your planning on building a power-house engine, 1.6 rollers might not be the best fit. But on a 'mostly' stock SBC used for Street driving; Go For It !
Old Oct 30, 2012 | 09:48 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: Roller Rockers
Thanks guys! Added a new pigtail, connected it to the sensor, cleared the code and now it runs like it is supposed to! Seals are next!
Old Oct 31, 2012 | 05:25 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: Roller Rockers
White smoke on startup (not because it's cold outside) is valve seals, blue smoke on startup is rings. At least, that's what I've been taught. Metal expands when it warms up, so the rings could be contracted enough when they're cold to have some blow-by, but when they heat up they expand enough to fill out the bore and there is less or no blow-by.
Old Oct 31, 2012 | 03:23 PM
Abubaca's Avatar
Re: Roller Rockers
Or perhaps the HEADS, CAM, INTAKE and tuning.....but sure....I'm sure the rockers helped. That's like discussing which has more calories, celery sticks or a quarter pounder, then saying that the sesame seeds on the bun added to the higher calorie count.
Old Oct 31, 2012 | 04:16 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Roller Rockers
Old Oct 31, 2012 | 04:41 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Roller Rockers
I felt a little increase.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
