question about 85 iroc 305 tpi air box?
Old Nov 22, 2012 | 05:13 PM
bowtie lover's Avatar
Car: 1985 iroc z
Engine: 5.0
ok i started putting my car pieces out and looking at them. i have the bottom part to the air filters where the actual filters sit but i dont have the top part where it connect to the boot to the throttle body. im not sure what this part is called and i was wondering what its called and if there is a better one out there for this type of car
Old Nov 22, 2012 | 06:44 PM
my89camaro's Avatar
Car: 1989 Iroc-z camaro
Engine: 305ci HO
Transmission: manual 5speed
Axle/Gears: Borg Warner w/ 3.08 gears
Re: question about 85 iroc 305 tpi air box?
is it u shaped or v shaped? either way if im understanding you right its just the top of the air box. you can find them at just about any salvage yard with third gen camaros. cheaper than online to. i bought one for my 89 iroc 305 for 5 bucks. post a pic if you can so i can see what exactly your refering to
Old Nov 22, 2012 | 06:49 PM
Car: 1985 iroc z
Engine: 5.0
i can take a pic of it but the problem is i dont have it but i can show u where it goes if that would help you
Old Nov 22, 2012 | 09:50 PM
my89camaro's Avatar
Engine: 305ci HO
that would help a lot just so i know which part or the intake your having trouble with
Old Nov 23, 2012 | 04:46 PM
Car: 1985 iroc z
Engine: 5.0
Car: 1985 iroc z
Engine: 5.0
it goes from that boot over the 2 air filter spots
Old Nov 23, 2012 | 11:32 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
http://www.hawksthirdgenparts.com/pr...y%2C-Used.html
This is the part you are looking for. Thankfully, as my98camaro pointed out, they are easily available in the junkyards as the 2.8L MPFI V6 used the same air box. I purchased my replacement upper piece for $10 locally, so you shouldn't have to shell out much for one.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
