fuel leaking out of vacuum port on regulator
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i suppose that means replace the diaphragm or regulator assy...
i have an adjustable holley (p/n 512-501) on there right now but why would that be (supposedly) for the 5.0L only when the pressure band is 35-65 and a 5.7L runs about 43ish... same fuel rail... apparently they have no tech line to answer the question, either?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel leaking out of vacuum port on regulator
Diaphragm is split or broken
All TPI's run the same pressure; 39psi @ idle, vac connected , 43ish with vac line disconnected
The different size of the injectors (19 vs 22lb ) controls the amount of fuel supplied
As said however, they're the same. There's no difference in any of the TPI mechanical components in any given year between when it's on a 305 and when it's on a 350. All the same.
Yes it's definitely broke. Get a new one.
Car: '91 Z28
Axle/Gears: 323's
yea, i guess they are behind the power curve on that one... just wondered cuz that is the afpr i have on my 5.7... took it off today and the diaphragm was deteriorated so yea, it would leak. saved a couple of bux thru advance auto, tho, with 20% off. better than nothing! and i was so close to getting that thing out of the garage finally - maybe next weekend now...
mdtoren
Aug 16, 2015 05:45 PM
