Corvette TPI Valve Covers on 3rd Gen ?
Old Dec 5, 2012 | 08:29 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Yes, I did a search...
Center bolt going on 91 305 TPI with center bolt...
Are these a simple switch?
Any holes, plugs, etc... that are different?
I know vette's had external EGR, but nor sure if this was dealt with via TPI base or heads / valve covers, etc...
Trying to find out before I get a set / freshen them up...
Thanks,
Rafael
Old Dec 5, 2012 | 08:05 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Re: Corvette TPI Valve Covers on 3rd Gen ?
I see no issues. The PCV and oil fill holes are in the same spots. Truth be told, I was looking for a set to polish and put on my engine about a year ago. Never got one tho.
Old Dec 5, 2012 | 09:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by lb9 GTA
I was looking for a set to polish .
Be aware they are magnesium , not alum
and a very rough casting once you have stripped off the thick factory paint used to fill all the holes in
Lots of work to hand polish ( can't machine polish because magnesium catches fire if it gets too hot ) and they need a clear coat once polished otherwise they lose the shine fast
Old Dec 6, 2012 | 12:57 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
How about some from an LT4? Had to drill a hole for the breather. Other than that, straight bolt on. But, ridiculously expensive.
Attached Thumbnails Corvette TPI Valve Covers on 3rd Gen ?-dscf2139-small-.jpg   Corvette TPI Valve Covers on 3rd Gen ?-dscf2140-small-.jpg   Corvette TPI Valve Covers on 3rd Gen ?-dscf2141-small-.jpg
Old Dec 6, 2012 | 05:58 AM
luvofjah's Avatar
I want them to match my TPI...
Yeah, everyone that I've talked to that polishes say they do not keep their shine... I read somewhere even after an hour... I asked about seals, powder coat, zoop seal, people have tried them all and no luck...
So now... I'm leaning towards having them cleaned up and chrome powder coating... as opposed to chrome.....
Rafael
Old Dec 6, 2012 | 07:45 PM
lb9 GTA's Avatar
I Didn't know that. Good thing I gave up on the idea.
Old Dec 6, 2012 | 07:59 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I have the composite vette valve covers also. NIce clean black look. as said above not cheap.
http://www.ebay.com/itm/92-93-94-95-...d42df5&vxp=mtr
Rafael,
Ive polished a few sets of those magn. covers. very porus. Ive clear powder coated them with no problem.
Old Dec 7, 2012 | 12:09 AM
watajob's Avatar
Car: 92 T/A 'vert
Rafael,
*GULP* Mine were even more as the LT4's are cast to fit roller rockers. And, there were less of them made.
Old Dec 8, 2012 | 07:54 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Just an example. Ya the lt4 are diff. No drip rails inside to clear 1.6 rr's.
I got mine cheap well traded my aftermarket aluminum ones for these ones.
If I was to pay for them I would have for the canton fabbed aluminum ones and powder coated them black.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
