Who needs an LSX.... TPI can do it!
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Another 355 TPI car lays down big numbers and takes over "King of the West Coast" TPI cars.
Congrats to Adrian (topteam54) outstanding results!
431 RWHP 429 RWTQ
Super Ram, XFI 280, AFR 195's, Dyno Don shortys, Tremec T-56, 3.73 Strange rear.
431 RWHP 429 RWTQ
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Who needs an LSX.... TPI can do it!
This thread is useless without dynographs for the rest of us to ooh and ahh over.
I am not jealous. I'm too lazy to do the work needed to make power with TPI but I give props to the people who want and do and eagerly read the threads.
I'm much happier with my LT1 and someday will make the jump to Gen 3/4. Or I might sell the car before I get there. Who knows.
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
I'll admit, I'm jealous
those are excellent numbers!
those are excellent numbers! Member
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
Thanks Kevin for a great tune. Allen and Don of course for the help and work. Especially when I was frustrated with this car.
Dyno charts and Video of the pulls are out there. Hopefully they will be posted up soon for all those that "proof".
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
hard to get a LSx to make that kind of torque unless you are 6.0 or higher displacement.
Very strong numbers for those heads/cam. Good job
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Wish we had guys that tune like you SoCal guys do...!
It's only a 31hr drive down there...
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I was there as a witness. That was one remarkable demonstration of power from a 355 cubic inch motor with a Super Ram. Just think with a couple of tweaks to the exhaust system, maybe an electric water pump or an under drive pulley, it just makes me wonder how much higher it could go. Could it be 440+ horsepower to the rear wheels? Just amazing.
Car: 92 Z28
Engine: Boosted LSX
very nice #'s. now just think toss a 420 cubes under there. Kinda like LPE did back in the day.
would be a killer trq monster
I was there as a witness. That was one remarkable demonstration of power from a 355 cubic inch motor with a Super Ram. Just think with a couple of tweeks to the exhaust system, maybe an electric water pump or an under drive pulley, it just makes me wonder how much higher it could go. Could it be 440+ horsepower to the rear wheels? Just amazing.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
For those who don't believe it then here's the video. Enjoy!
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Is he rocking the new AFR heads? Also, where was peak power with that superram?
I might need to send one of my setups off to get ported and welded.
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Any more details on the engine spec?
Transmission: T700
How about the camshaft?
Was there any work done on the heads?
What size injectors etc?
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
Nice job bro. Where u get injectors from? Wonder what mine will push with 355, accel lower intake AS&M runners,ported plenum, bbk 58mm tb, 195 afrs, t56, 373s edelbrock headers...
As far as your combo the edelbrock headers are going to be a restriction point. What version AFRs and cam are you running? Also might want to look into getting your base worked over and ported. Good luck
If you havent seen other dyno videos we made, go to youtube and type in my name and you will see all the dyno videos i posted.
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
VERY impressive. The HP curve looks very nice as well.
It looks like more maybe could be had with more fuel or does it make more leaning out at the top end?(per the AFR at the bottom)
Car: 89 Iroc-z
Transmission: TH400
Still shows a restriction on top end with hp and torque peaks so close together. That cam wants to spin up abit more. What was done to the runners? This use the welded up bases that flow 280-300 cfm?
Yes, that is a welded and ported base flowing 328/332.
The runners are Siamesed by 89GTA
On another note, I think I have come across the answer to the top end falling off, still researching but from my findings, all the cars we have done with manual trans, we have started with the 305 program and they all do the same thing, but not so with the auto cars. I will be looking into redoing the chip on my car starting with an AUJP prom and importing the manual tables to it.
Car: 89 Iroc-z
Transmission: TH400
Thats interesting... What in the bin would cause that to happen whether its manual or auto?
Try the manual vette bins to see if it makes any difference. I would have thought runner length of the superram runners or diameter but if they are siamesed and total runner length is below 15", then it should peak in the mid low 6000's like it does on stealth ram miniram cars. Last one i tuned had valvefloat but was on its way to peaking by 6100-6200 in a 360" motor
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Pretty impressive HP from that motor. The TQ peak of 5100 (although it is pretty flat) is something odd to me - especially for a hp peak of 5700...
Here is the graph....
Notice on the green one where I ran it out to 6000, it fell at 5700 just like all the others.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
When we first started doing our own bins, I thought there was something different about the Corvette bins that doesnt work with the F-body setup. I know the oil temp sensor is one, and that can be turned off in the chip, but wasnt there something else?
Car: 89 Iroc-z
Transmission: TH400
Fans were different but there is a flag you can turn on/off as necessary. Stock arap bin in fbody runs fan on all time at key on. Its wired differently or something like that. Flag you select is suppose to correct that. I dont recall what else.
Very least you can try bin compare and just copy main tables over.
Nice numbers! Great job you guys! It's been a looooong time but I think I started with a Vette bin and turned off an oil sensor code for mine...if my memory is worth a crap still. lol
Car: 1989 GTA
Engine: 369 TPI
I think Don has hit the nail on the head with the 305 manual bin. All the manual cars to the same thing. Must be something "hidden" in the code to help keep from over revving the motors and keeping the warranty in check. The automatic cars have no such problem as I have had mine up to 6750 rpm with no sign of a let up. So maybe working with the Corvette bin might be the answer. OK Kevin you have some work to do.
Edit: If this problem gets resolved this will open up a new world for the manual TPI cars. Because of this they have been held back.
Edit: The reason I picked that runner length was to ensure that Adrian picked up the 3rd harmonic induction wave.
Car: 89 Iroc-z
Transmission: TH400
Might be a question for rbob. I will do some bin compares but not sure if that will show anything. Its not actually hitting a limiter? What did air fuel and timing do after that rpm? Base pulse width limiter at all?
This a speed density car? My buddy uses 730 ecm on his 406 to 7000 rpm just fine. t56 car. I will ask what he uses. There is a pulse width limit in the code but you dont seem to hit that until 460 whp with high duty cycles. Or was it duty cycle limited only? I just know that motor capped at 468 whp and wouldnt respond to changes because code was limiting the inj bpw. There is a thread here somewhere on it
Edit: he uses aujp bin
Car: 1989 GTA
Engine: 369 TPI
They are speed density cars. I will let the either Don or Kevin answer the other questions even though I "think" I know the answers.
So, we'll assume the DFI guys have no issues revving either? I remember seeing a 3rdgen stock eliminator car on a dyno session once with Accel DFI, long tube runners, lots of cam duration but factory spec lift to meet requirements, etc,.... and it revved to 6500 no problem! I'm thinking 6800 was when we shut it down. Power was flat past 6 but never seemed to fall off! Car ran 11.90's I think. It was nuts!
Car: 1991 RS
Engine: 5.0
I read something similar in one of the Chevy mags about a similar car. 305 TPI car ran mid 11s. Don't remeber what computer setup it had though.
Nope! We're only using the factory ECM and harness. This way we can show what can be done with factory parts without wasting money. Do we have the best combos? No. But were not too far off. We are still learning and sharing it with the world with nothing to hide. We are the Dyno Kings of SoCal. We know what works and what doesn't.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
So when a superram makes power with a TPI computer, it's still considered TPI?
Nonetheless, very impressive numbers, always good to see an EFI Gen I make real power...
What would you call it? Isn't it an expansion of the TPI system? It has runners like the stock set up, it has a plenum like the stock set up.
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Impressive!
I know that So Cal doesn't have many dragstrips, but track results would be cool to see. Install a 9" or 12 bolt, slicks, and go run some low 11's!
I've had arguments in the past with people who went superram/miniram with DFI or whatever saying it is still a TPI car. It was a TPI car in that case.
But still, using a factory TPI computer with those numbers is impressive...
