lunati cam
Old Dec 20, 2012 | 05:26 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
lunati cam
has anybody use the lunati cam part number 20080679 EFI Hyd Roller Cam - Chevrolet 5.0-5.7L 268/279. in a305 or 350 TPI
Old Dec 20, 2012 | 06:21 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: lunati cam
Too big for Tpi car.
Old Dec 20, 2012 | 06:26 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: lunati cam
is it made just for a lt 1 or ls 1.and what is good cam for 305 tpi or 350 tpi,
Old Dec 20, 2012 | 06:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: lunati cam
Yeah lots of them will say they are made for your car,but they assume that you are changing springs too or you already are taking this into account. Crane powermax 2032 cam or any of the "compucams"
Old Dec 20, 2012 | 06:31 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: lunati cam
I think your car is a flat tappet
Old Dec 20, 2012 | 06:42 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: lunati cam
http://www.summitracing.com/parts/crn-114132
Old Dec 20, 2012 | 08:36 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: lunati cam
yes it is but i am getting ready build the 305 or 350tpi i am just trying to get all the info that i can .
Old Dec 21, 2012 | 12:11 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: lunati cam
So your planning to convert to a roller cam?
Old Dec 21, 2012 | 12:27 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: lunati cam
Cam is just part of the equation, its not a one size fits all.
Fill out a cam request card from one of the makers.
For a cam recommendation you need to know,
compression, heads, intake, exhuast, gear ratio, intended use etc....
Old Dec 21, 2012 | 12:30 PM
Car: 1971 Camaro
Engine: 427
Re: lunati cam
That cam would be good for a modified tpi. Too much for a stock tpi as stated.
•Duration @ .050 (Int/Exh): 215/224
•Gross Valve Lift (Int/Exh): .489/.489
•LSA/ICL: 112/108
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1500-5750
Old Dec 22, 2012 | 12:08 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: lunati cam
what would i need to do to use this cam. IF I BUILD A 350 TPI WITH A 3.73 REAR
Old Dec 22, 2012 | 12:17 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: lunati cam
373 rear is too much for TPI auto car.
Old Dec 22, 2012 | 12:18 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: lunati cam
342 is about the max,but you wouldn't really see any difference between your stock 323 and a 342 anyway.
Old Dec 22, 2012 | 12:22 PM
Car: 1971 Camaro
Engine: 427
Re: lunati cam
Matching valvesprings.
For that cam to work well, you would need, headers, cat back, ported tpi base and upper, aftermarket runners, and good heads.
If you go to lunatis website, or Comp cams, you can fill out a cam suggestion form. They will tell you what cam to run and what parts are needed to match it.
Old Dec 22, 2012 | 12:26 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: lunati cam
are you set on using that cam?
Old Dec 22, 2012 | 12:38 PM
Car: 1971 Camaro
Engine: 427
Re: lunati cam
It appears that way.
Old Dec 22, 2012 | 01:37 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: lunati cam
i guess what i need to say how do i need to build the 350 tpi to get a little bit more power tahn stock
Old Dec 22, 2012 | 01:41 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: lunati cam
and i also can type good it is not a 3.73 is 3.23
Old Dec 22, 2012 | 01:51 PM
Car: 1971 Camaro
Engine: 427
Re: lunati cam
Read some of the many many build threads on this site.
You know what they say, " there is more then one way to skin a cat"
To get a "little more power then stock" I would have some mild porting done to the 083 heads and tpi plenums.
Headers and catback
Contact one of the cam makers for a mild street cam sugggestion. Don't over cam, thats the number one problem when it comes to cam buying.
Old Dec 22, 2012 | 01:52 PM
Car: 1971 Camaro
Engine: 427
Re: lunati cam
3.23 is a good gear for your application.
Old Dec 22, 2012 | 02:10 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: lunati cam
i see that you have 350 what have you done to your car. hope yo do not mine me asking .
Old Dec 22, 2012 | 02:16 PM
Car: 1971 Camaro
Engine: 427
Re: lunati cam
Well lets see, first I ported the stock heads, milled them, added a Holley Stealth Ram, HEadman shorties, catback,
Then Swapped in a very wicked 427 bbc.
Then, sold that, and am going back on the street.
Building another 350, heads will be either engine quest hybrids, or maybe vortecs. Ported base, SLP runners and ported uppers.
Probably going with a voodoo 60121 cam.
Headmen shorties again.
Shooting for close to 10:1 compression.
Once its back together, I'll get a tune.
Old Dec 22, 2012 | 02:33 PM
tcrisp's Avatar
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: lunati cam
sounds like you are having alot fun . i just need to see what route i will go with my car . thanks for your help. have a great and safe christmas
Old Dec 22, 2012 | 02:41 PM
Car: 1971 Camaro
Engine: 427
Re: lunati cam
Or wasting a lot of money!
The 427 was wicked. I was trying to go outlaw racing, but couldn't afford it.
Got sidetracked for awhile.
Should have kept the stealth ram and stuff, now I am starting all over again, with an empty engine bay.
I painted the car 8 years ago, but am going to repaint it this spring.
Putting an offer in on a house, if it goes through I'll be moving in Feburary. Once I get settled in the new place, I am going to tear into the Iroc full on. Will start a rebuild thread then.
Best advice, decide what you want to do with the car as far as usage and performance and stick to it. If you are not planning on racing competively, don't worry about Max HP.
Look around at what others have done.
Happy holidays to you to!
Old Dec 22, 2012 | 08:09 PM
racerx520's Avatar
Re: lunati cam
did 3.73 in my stock tpi. get to 4th gear at 25 mph when cruising around town. but lay on the gas and holy hell it moves!! the rear of the car just basically walks around the car when i make turns. top speed is probably like 110 now too.
Old Dec 27, 2012 | 01:27 PM
1967c10's Avatar
Car: 1967 c10 stepside short.
Engine: 350sbc L98intake Holley HP EFI
Re: lunati cam
I am running Lunati 60104 on my longtube TPI 350 060" over. works great for me, great response, good torque. Not completely tuned yet so have no dyno numbers. But seems to pull good to round 5500.
Old Dec 27, 2012 | 01:58 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: lunati cam
That cam wont work for him,he needs a computer compatible cam for his TPI.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
john204481
Sep 7, 2015 03:22 PM
