Help! 350tpi doesnt run right until it has been running several minutes
Old Feb 20, 2013 | 09:35 PM
Bjbcwb's Avatar
I recently traded for a 91 rs that has had the 305 replaced with a 350tpi. Starts up fine but sucks alot of air and if u were to drive off there would be alot of hesitation unless you let the vehicle run for 6 or 7 minutes. After this, it drives fine no hesitation but if I turn it off and instantly start it back I will have to wait another 6 or 7 minutes. Also smell gas while idling. Any help would be appreciated
Old Feb 21, 2013 | 01:00 PM
Jhook's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0
Re: Help! 350tpi doesnt run right until it has been running several minutes
Id check and make sure everything was traded out properly. Check fuel pressure, injectors, EGR valve, make sure all vacuum lines are going to the proper location..stuff like that. Someone might have also put in the wrong injectors. Can be easy to confuse the injectors from a 305 and put them in a 350.
Old Feb 22, 2013 | 12:17 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
I would run thru sensors and make sure there and plug and working
check plugs and wires etc
then check vacuum lines
also check if intake installed correctly
check fuel pressure
for gas smell did the hook up evap ?
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
squiggy2
Aug 9, 2015 09:30 PM
Sherpajames
Aug 7, 2015 06:56 PM
