86 305 tpi idle drops to 500 no idea where to start HELP
Car: 1986 Trans am
Engine: tuned port 305 LB9
Axle/Gears: .323
I have a 1986 305 tuned port trans am and this morning the idle dropped to 500 when i wasn't giving it gas. It sounds very rough as if it might die.
I checked the engine codes and it was code 12, 22, 33, and 36. can anyone tell me what these mean and where to start??
Thanks, Grant
Thanks, Grant
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 305 tpi idle drops to 500 no idea where to start HELP
you might want to start with the low tps voltage first , hopefully this is just a bad ecm not a maf.
Engine: Lb9
Transmission: M20
go thought the trouble tree chart for code 22 at chevythunder.com
Car: 1986 Trans am
Axle/Gears: .323
okay i have a few questions what does ALDL and SES stand for?
Engine: Lb9
Transmission: M20
ALDL=Assembly Line Communication Link
Ses is the service engigine soon light also called check engine light or mil malfunction indicator lamp.
Car: 1986 Trans am
Axle/Gears: .323
Okay I disconnected the battery and drained the energy out of the car and put out on learn mode I guess its called. But the only code now is just 22 but I don't really understand what I am supposed to do even after reading that troubles tree. Can you please explain in a dumb Ed down version haha?
Engine: Lb9
Transmission: M20
Car: 1986 Trans am
Axle/Gears: .323
My coach called me Ed anyways so if I have proper voltage measured with a multimeter then it is the ECM if not than its wiring. Basically it right? Dang I sound dumb but i'm new to this haha
Car: 1986 Trans am
Axle/Gears: .323
Oh and it was getting bad throttle response and it fixed that so it ain't the tps
Engine: Lb9
Transmission: M20
On pin c14 of your ecm you should have close to 5v and almost the same reading at the tps grey wire. The blue wire at the tps should show .54v dc if the tps is adjusted correctly the same voltage will show at the ecm pin c13. All of this testing is with the key on. If all this checks out ok deoble check the ground connection behind the passenger cylinder head.
Car: 1986 Trans am
Axle/Gears: .323
Okay I will check this tomorrow after school and let you know how it goes.
Car: 1986 Trans am
Axle/Gears: .323
i found this random red wire by the ecm it goes through the firewall and ends it isn't supposed to be there I'm certain could this be the cause of the code and the idle?
Engine: Lb9
Transmission: M20
It hard to see it may have been hooked up to the tach lead and ran under the dash at one time hard to say.
Car: 1986 Trans am
Axle/Gears: .323
I looked a little closer and took it out and the red wire meets a white wire that runs into the harness and yeah it its tired into the tach part. Any idea what this could be?
Engine: Lb9
Transmission: M20
some one had a tach in the car at one time. were you able to check the tps voltage ?
I just remembered another guy with a 86 had a low idle the memcal in the ecm is a aum.
https://www.thirdgen.org/forums/cool...ot-coming.html
Car: 1986 Trans am
Axle/Gears: .323
Not yet I keep getting called into work early. I was going to do a continuity teddy then check the voltage.
But as soon as I can I will and what is aum?
Engine: Lb9
Transmission: M20
teddy lol inside the cars computer is has a chip. there are letters on the chip called a brodcast code. The one marked aum has been known to have issues. But your throwing the 22 as well so you might want to resolve that first.
Car: 1986 Trans am
Axle/Gears: .323
I just checked the signal at the tps and there was a grey that measured 5 volts a grey with a red stripe that was 4.5 and a black that was.21 volts. None of these changed while pressing the portal to the floor with the key on. any ideas?
Engine: Lb9
Transmission: M20
are you sure your on the tps ? the top wire is black and is the tps ground. The center wire is blue the tps feedback to the ecm. The bottom wire is grey the 5v reference from the ecm.
Engine: Lb9
Transmission: M20
the black wire is showing voltage ?
Car: 1986 Trans am
Axle/Gears: .323
Yeah on the left side of the throttle body I replaced it i'm sure it is the tps
Engine: Lb9
Transmission: M20
the tps is on the right side of the throttle body.you should not be getting voltage through the ground. if you unplug the 3 plug harness and check for power on the black wire there shouldn't be any. it sounds like your new tps is bad.
Car: 1986 Trans am
Axle/Gears: .323
I checked the actual writes and there are no wires going to anything near the tps on the right side just the throttle and the throttle spring i'm more confused than when I started haha
Engine: Lb9
Transmission: M20
your confused with your right and left lol, all parts in your car are referenced s if you were sitting in the drivers seat.
Car: 1986 Trans am
Axle/Gears: .323
Oh haha dang I suppose you were right calling me Ed haha. Anyways so if I am getting voltage from the black wire what does that mean?
Engine: Lb9
Transmission: M20
the wiring color doesn't seem to jive ed lol, Im not sure if some one did a repair there at one time. the black wire is suppose to be a ground for the tps, mat,cts and gounds behind the passinger cylinder head.
Car: 1986 Trans am
Axle/Gears: .323
I'll check the color deeper but three voltage means is not grounded properly?
Engine: Lb9
Transmission: M20
if you pull of the cts connector and check the black wire for voltage its hooked to the black wire of the tps if you dont have power on the cts the 2 wires are not conected.
Engine: Lb9
Transmission: M20
its sounds like there is something hooked to the ground wire or its shorted to power some where.
Car: 1986 Trans am
Axle/Gears: .323
Alright grey is grey black is black and grey and red is actually ok so you ate still smarter than me note what?
Engine: Lb9
Transmission: M20
yes still with the key on there should be no voltage there at all
Engine: Lb9
Transmission: M20
well grounds are not suppose to show power, I would leave the tps and cts unplugged . With the key on there is a 2 wire connector on the passenger side (right side) right net to the distributor the pigtail goes from the 2 wire pigtail to the mat under the plenum. Disconnect that and see if you have power on the black wire on the mat harness the wire thats running back into the loom.
Car: 1986 Trans am
Axle/Gears: .323
So I can driver it without ether tps or that other hooked up?
Engine: Lb9
Transmission: M20
no you need to figure out how power is getting to the ground
Car: 1986 Trans am
Axle/Gears: .323
Cause I have to go somewhere soon I don't think I will have any more time today
Engine: Lb9
Transmission: M20
oh ok slap it back together
Car: 1986 Trans am
Axle/Gears: .323
Okay the idle is doing it more frequently since I have messed with it could this mean that it is around the cts and tps?
Engine: Lb9
Transmission: M20
you could tap into it and reground it but I was having you unplug the tps, cts and mat to see if as you unplugged one if the voltage went away if it did that sensor would have a issues and would need to be replaced.
Car: 1986 Trans am
Axle/Gears: .323
I Brooke down yesterday cause my battery died and I was looking st my alternator and the ground on it was very very weak and I fixed out now it idles much better and three voltage on the ground its .02 instead of .2 like last time. could have been causing that this whole time?
12 SES light test. No eng RPM. System is normal.
22 Throttle position sensor circuit - signal low
33 MAF (Mass Air Flow) sensor - signal voltage too high
36 Ignition system circuit error.
You need a book that tells you the code meanings in detail with flow charts which tell you how to troubleshoot. Documentation is readily available on the net. The best book I've found is the GM factory shop manual, available for about $20. Just google it. I also have an engine code manual which gives good info about TPI cars such as yours, with good write-ups on each of the sensors. If you're going to work on it yourself I'd recommend building a library. It's not expensive.
With these computerized engines I believe you need good documentation to conquer them on your own.
Car: 1986 Trans am
Axle/Gears: .323
I know it has been a while but I finally gt to check the mat under ether plenum and its the same exact voltage and unplugging it does not change voltage at the tps or the cts. So that means its wiring? Or possibly the ground? How do I go about checking The ground?
