RPM while braking
RPM while braking
92 3.1v6 tpi auto. Changed my dist cap and rotor at weekend as well as ignition module. Now seems to drop rpms while braking lower than before (around 500rpm) but feels rough when I come I a stop, I have to put it into neutral or park to get rpm to level out again at 800rpm. Car was throwing a MAP code 6 weeks ago but sorted itself out after I did a battery unplug. Brakes have a whoosh sound and are spongy/sh*t.
Got a feeling I may have disturbed a vacuum line when messing with dizzy?
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: RPM while braking
If you disconnected the battery, you may have to an "idle relearn". Check out the link, #7. Good Luck.
https://www.thirdgen.org/forums/v6/6...bird-3-1l.html
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
