Has anyone ever used a Holley Stealth ram on 083 TPI heads?"
Old Mar 7, 2013 | 12:11 PM
Demonic13's Avatar
Car: 1991 Chevrolet Camaro 25th Anniv.
Engine: 5.7L 350 TPI
I am looking to get a stealth ram for my 1991 Camaro z28 with a all stock l98 cast iron heads. A guy here has Weiand Stealth Ram EFI Intake Manifolds 7540 for sale complete with fural rails and all.
the seller claims he has used a stealth ram on 083 TPI heads and that the slotted center bolt holes fit the later style intake bolt pattern fine, can anyone confirm this?
The guy told me:
"The D shaped runners are only in the middle tunnel ram portion where the lower intake meets the top plenum part, the intake runners are normal sized. Summit lists as 86 on down but I have used this on several sets of 87-92 305 and 350 heads. The reason they don't list it as fitting the 87-92 is due to that 70 vs 90 degree intake bolt issue that is a non-issue as long as you use grade 8 bolts w/ washers. You won't need a tune, a tune would definitely help maximize your power but it won't be mandatory. It would have been mandatory if your car was an 85-88 TPI due to the cold start injector issue.
Because you'll have the adjustable fuel pressure regulator, if you have any lean hesitation issues you can just turn the pressure up until it runs the way you want it. If you end up deciding to stick w/ this setup for the long term, a dyno tune would go a long way in getting the most HP and efficiency because the stock tune was not designed around this intake, or headers, or any of your other add-ons."
Thank you.
Old Mar 7, 2013 | 02:17 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Has anyone ever used a Holley Stealth ram on 083 TPI heads?"
The guy told me:
Thank you.
It's drilled for both patterns (i.e, Slotted). like most intakes these days.
You should have posted this question in the Alternative Port injection board, since this one concentrates more on TPI.
http://www.z28.com/showthread.php?10...R-bolt-patter&
-- Joe
Old Mar 7, 2013 | 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Fits fine. As said above. They sell angled/beveled washers for the center bolts to make the bolt head seal flat on the intake but dont need them to work.
Ports are abit bigger than head opening but works. I saw huge gains on stock L98 with supporting mods
Old Mar 7, 2013 | 02:29 PM
Demonic13's Avatar
Thank you so much for clearing that up I am going to but it now. THANK YOU.
Old Apr 9, 2014 | 10:18 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
so just to confirm the stealth ram intake will work with both the stock TPI heads as well as any other sbc heads (angle washers suggested but not required)? Because I have the stock TPI set up now but am going to do both the heads and intake in the future, but don't have money for the heads yet. Please tell me this will work and I will order it tonight!!!
Old Apr 9, 2014 | 10:33 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Yes
Old Apr 9, 2014 | 10:37 PM
nuggie's Avatar
is there a difference between the holly stealth ram and the weiand? besides as it looks as the holly only come as kits
Old Apr 11, 2014 | 12:33 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
They are the same. The holley version is now sold as a stand alone kit and wieand is the manifold only. Keep in mind you will also need to order the fuel rail kit and IIRC injectors as well
Old Apr 11, 2014 | 09:37 AM
nuggie's Avatar
Really I was yold the stocl fuel rail woll work just the bolt holes were in a dofferent spot. Sorry for bad typing on a phone
Old Apr 11, 2014 | 08:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Don't believe everything you re told .
Check it out yourself visually
Have a better look and work out where the fuel reg on the stock fuel rails would be
if the rails were mounted on a HSR base ?????
Old Apr 11, 2014 | 09:14 PM
Car: 91 Trans Am
Engine: 355 TPI
Whoever told you that is wrong. There are plenty of HSR installs documented on this site that point that stock fuel rails do not work with this intake
Old Apr 13, 2014 | 03:39 PM
duke22's Avatar
Car: 1988 IROC convertible
Engine: 5.7 TPI
Axle/Gears: 3:73:1
I have an '88 IROC convertible with 5.7 tpi. I've added shorty headers, adjustable fuel pressure regulator, true 2 1/4" dual exhaust, airfoil and 3:73 rear gears. And by the way I checked the injectors and they were 19lb. injectors! It ran a best of 14.38 in 1/4 mile. I've added an hsr with 24lb. ford injectors. I was wondering what it should run in 1/4 mile now??
A
Old Apr 13, 2014 | 05:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Probably slower unless you get a custom tune for the new bigger injectors , the engine will be way too rich
Old Apr 16, 2014 | 06:15 PM
duke22's Avatar
Engine: 5.7 TPI
Axle/Gears: 3:73:1
I checked the spark plugs and they're all tan in color. So I thought they were burning pretty clean. timing is set to 15* and fuel pressure is set at 43 pounds. Can't find anyone in my area to tune it. I'm gonna take it to the drag strip in a couple weeks and see what it will do.
Old Apr 17, 2014 | 12:45 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Supporting mods as in H/C/I?
And when you say 'they sell," could you provide a brand or part number? Thanks to this thread ill be able to add another piece of the puzzle to my HSR swap. I have an 89 5.7 tpi so i was worried that it wouldn't fit.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
