Potential fuel pressure issue
Old Mar 7, 2013 | 08:01 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
I've got the stock 305 TPI in my car. Around June of last year, I noticed my car acting weird - especially on hills. When I start to give the car more throttle (to climb a hill or accelerate quicker), sometimes the engine drops a few hundred RPMs. The more gas I give it, the lower the RPMs drop. Sometimes, letting off the gas and getting back on the gas fixes the issue. Other times, the engine will correct itself and raise about 500-600 RPMs in a matter of seconds without me changing the amount of throttle I'm giving the engine.
On even more rare occasions, the car will jump between about 1800 and 2000 RPM's while climbing hills every second. Giving more throttle bogs the engine down more, so usually I just keep the throttle constant while I make my way up the hill bouncing between those two RPMs. Once I reach the top of the hill, the car usually corrects itself and raises about 500-600 RPMs to where the engine should be running at.
So after almost a year of this, I'd like to fix this. It's a sporadic issue that doesn't happen every time time I climb a hill or give the car a lot of throttle, but it happens often enough that it's getting annoying. And every time it happens I wonder if the car will die while I'm climbing a hill or merging onto the freeway. I'm thinking it's a fuel pressure issue (fuel pressure regulator maybe), but I thought I'd come and ask about it on here before I start tearing into my car.
Old Mar 7, 2013 | 11:03 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Potential fuel pressure issue
Have you tested the injectors yet?
Old Mar 7, 2013 | 11:55 PM
Car: 1991 Z28
I have not. I checked the technical articles and didn't see anything about testing fuel injectors. I Googled "how to test fuel injectors" and found a few that said check the resistance of the fuel injectors with an OHM meter. Is this a good method? If it is, what kind of resistance would tell me if the fuel injector is good or bad?
Old Mar 8, 2013 | 07:02 AM
ninetyone's Avatar
Axle/Gears: 3:42
Old Mar 8, 2013 | 05:37 PM
Car: 1991 Z28
Alright, I got out there today and got these readings:
Cylinders 1,2,3,4,5,7 all had readings of 16.3 or 16.2 (they jumped between the two)
Cylinder #6 had a reading of 15.3 and cylinder #8 had a reading of 15.9.
Is the 1 ohm difference on cylinder 6 giving me issues?
Old Mar 9, 2013 | 11:40 AM
southbay08's Avatar
Cold they look good, check them hot to see if the readings are the same
Old Mar 9, 2013 | 11:42 AM
southbay08's Avatar
1 0r 2 ohm's arte within spec
Old Mar 9, 2013 | 07:37 PM
Car: 1991 Z28
I went out for a 10 minute drive today and got the car up to temperature. Came back and took some measurements.
Cylinder #1: 17.1
Cylinder #2: 17.7
Cylinder #3: 17.2
Cylinder #4: 17.5
Cylinder #5: 17.0
Cylinder #6: 16.2
Cylinder #7: 17.1
Cylinder #8: 17.2
Old Mar 14, 2013 | 05:10 PM
Car: 1991 Z28
Bump
Old Mar 20, 2013 | 12:45 PM
Car: 1991 Z28
I'm still having this issue. Anyone?
Old Mar 20, 2013 | 12:47 PM
ninetyone's Avatar
Axle/Gears: 3:42
If this is happening on hills ,then it is a pump issue.
Old Mar 20, 2013 | 03:46 PM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Have you checked your fuel pressure yet?
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Kaweh
Aug 9, 2015 02:54 PM
