fuel pump relay
Car: 89 IROC-Z28 Camaro
Engine: 350 TPI IROC
fuel pump relay
my car will run only if i push on the gas, 12v to red wire on the relay, nothing on all the others, i tried jumping it under the dash and no fuel pump sound but i can hear it prime when i turn the key on though, and thoughts please
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: fuel pump relay
Have you bypassed the oil pressure switch ?
Engine: Lb9
Transmission: M20
Re: fuel pump relay
jumper the switch grey wire to orange wire the pump should come on.
Re: fuel pump relay
i did and it works fine now, the terminal was very loose, thank you for your input, i appreaciate it
Re: fuel pump relay
now the SES light flashes and wont stay running at an idle, i jumped the fuel pump relay and the pump stays on but the light flashes and wants to kill it.
Re: fuel pump relay
if i pull all fuses the light still flashes until i pull the eng/control fuse then everything shuts off, i think its a wire not connected but i dont know which wire to trace down, i have the 3000 page manual but its kinda hard to understand some of it
Re: fuel pump relay
the grey wire would read 12v after car was off for 10 sec and turned on for 2 sec but dropped quickly, i cant find if its supposed to stay at 12v or if is supposed to drop to 0v
Re: fuel pump relay
i have about 5k under the hood replacing almost everything (stock) the harness, tps, ect, and O2 sensors are the last things left to be compeletly new
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Re: fuel pump relay
no communication with the ecm indicates the memcal in not seated correctly or is bad or the ecm is faulty.
Engine: Lb9
Transmission: M20
Re: fuel pump relay
the ecm grounds are behind the passinger cylinder head.
Re: fuel pump relay
those 2 wires cost me 2k last time and 6 months lol i couldnt find the problem after replacing everything and it was those 2 wires cut in half, i fixed and it ran perfect. so i look at those 2 wires 1st when i have a problem lol
Re: fuel pump relay
i know the vacuum leak code pops, 32, so the light stays on when its cold til i open the throttle all the way then the code would shut off til the motor sat and got cold. Now when its running the light stays on, car runs fine, then the ses light will flash or shut off and the car drops in idle or dies right with the light
Re: fuel pump relay
its an intermittent problem, it wont let the car start or run on its own, i have to give it gas to start and stay running. thats when the light will be flashing irregular
