MAF vs MAP
MAF vs MAP
Converting my old 1/2 ton to TPI. The plenum is for MAF; wish to use MAP. The Plenum doesn't have the hole or tapped holes to mount the sensor; wondering if I can drill into it for the vac line, and tap holes to mount. Anyone have knowlege of this? I prefer the longer fins of the earlier plenums, and would prefer to keep mine, I've got it polished. Thanks for your input.
Re: MAF vs MAP
To my knowlege the MAF systems had no MAP, the MAP was used only on the later (90-92) Speed density systems. If I can't adapt the plenum, I guess I'll get a later plenum.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: MAF vs MAP
You can use any vac port as a means of supplying a vac signal to a remote mount MAP sensor as the factory did with some installs
Usual recommendation is to keep the vac line as short as poss to reduce response time
Car: 82 Z28
Transmission: T400
Re: MAF vs MAP
https://www.thirdgen.org/forums/diy-...f-165-map.html
Or you rework the MAF harness to use the later '730 MAP ECM
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: MAF vs MAP
Yeah is easy to swap maf harness to map and run 730 just need the extra ecm connectors. 730 uses 3, while 165 has 2.
Remote mount the map and it will be fine
BumpaD82
Feb 26, 2016 02:57 PM
