afpr issue
Car: 91 Camaro RS
Engine: 305 TPI conversion.
afpr issue
i replaced my old injectors and afpr for southbay injectors and afpr. after pressurizing the fuel system i found no leaks. on initial start it wont turn over. i adjusted the afpr halfway down and double checked all vacumn lines. when i turn on the ignition, i hear the fuel pump prime. the fuel pressure goes to almost 50 then back down to about 11-14.
again i see no leaks or smell any gas. did i miss something?
Car: 91 Camaro RS
Re: afpr issue
yeah, i was missing something. i have a streetfire ignition box and did not hook it back up to the battery.
