85 distributor upgrade.
Ok so i was givn an engine and trans out of an 85 iroc-z (lb9) it did not have a distributor on it. Iv been doing a lot of research on these engines over the past 6mo or so but never realy looked into the dizzys so now its time to drop it in and no dizz. I would like to do an performance one since i have everything else perf. In it. But unsure of how to select one. Can someone point me in the right direction. I found this one but again am unsure if it will work.
http://www.ebay.com/itm/281018805830...84.m1497.l2649
Any help is appreciated
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 85 distributor upgrade.
Can't use that distributor with TPI, you need something computer-compatible.
A stock replacement one would be fine.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
It might be easier to find one on corvette forum. The hei computer controlled dizzy was used in the f body tpi from 85-86 and the y-body 85-91
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
The Icm 4 wire connector would née to be changed. You need a pigtail jumper from the icm to the coil for icm power and coil trigger and the power and tach lead of your body harness needs the ends changed.
Engine: Lb9
Transmission: M20
If your going to have the harness reworked now would be a great time to toss the 870 ecm and go with the 165 ecm or speed density 730 ecm.
Engine: Lb9
Transmission: M20
The baud rate , throttle response hardware on calibrations of the 1226870 ecm sucks IMO.
It would be a change in repinning and rewiring.
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Engine: Lb9
Transmission: M20
If you have a roller cam you would need a melonized gear
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
