Manifold leak?
Old Mar 20, 2013 | 06:49 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
Manifold leak?
I have a small leak coming from the manifold on the driver side towards the front by the alternator.is there any way to just fix that small area or do I have to take it all apart?and can I leave the injectors and fuel lines on to replace the gasket?
Old Mar 20, 2013 | 09:30 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Manifold leak?
You'll have to take it apart to fix it correctly. Removing the intake and replacing the gaskets isn't really that bad to do. Just take your time and keep track of where bolts go. IIRC, you don't have to remove the fuel rail or injectors to remove the intake.
Old Mar 20, 2013 | 09:35 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
Re: Manifold leak?
Well I'm not talking bout the valve cover gaskets. I'm talking about the base manifold gasket
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
tommy z-28
Oct 6, 2015 10:58 PM
bubbaz28
Sep 18, 2015 02:09 PM
bamaboy0323
Sep 12, 2015 07:14 PM
