a couple of questions, I am rusty
Car: 88 GTA "Cocaine"
Engine: 350 tpi
where can I get big mouth gaskets so I can port out the tpi like I did on my last car. last time I think they were mr gasket
where is the rpo list on my 1988 gta
what size injector should I use on a 350 tpi I was thinking on using these
http://www.southbayfuelinjectors.com...esign_lll.html
are these injectors any good the price is right
thanks guys
thanks guys
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: a couple of questions, I am rusty
Mr gasket 146 those are the injectors you need
Engine: Lb9
Transmission: M20
If the car has a center console check there other wise check on the cardboard piece under the rear carpet
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Rpo codes may also be in the trunk storage door. Open it with your key and look on the back side of the door.
Engine: 350 tpi
those dont look like the big mouth gaskets
I really dont care what brand they are just so I can enlarge the ports
I bought the injectors
Engine: Lb9
Transmission: M20
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Car: 1971 Camaro
Engine: 427
Mr. Gasket 146 TPI Runner Gasket Set : Amazon.com : Automotive
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
Look at how skinny the intake ones are between the runner ports on the pic.
Engine: 350 tpi
oh ok
I did not know that the mr gasket was that big. thanks for the help
just bought them.
now I need the carbite bit for cutting aluminum
I seen what I need on a episode of horsepower tv but I dont know where to get it from
just bought them.
Engine: Lb9
Transmission: M20
Accel 74195g ones are repackaged mr gasket 146
Engine: Lb9
Transmission: M20
That yellow ink on the packaging must have gold flake in it lol
Engine: 350 tpi
I have used a holley afpr and it was great. where should I get one from
or is there a cheaper alternative that I can adjust with the intake still intact
Car: 1971 Camaro
Engine: 427
Engine: Lb9
Transmission: M20
