carb to tpi fuel?
Old Apr 25, 2013 | 12:28 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
carb to tpi fuel?
So this 86z is a factory carb car fuel lines up passenger side so what should i do for a fuel pump would it be worth the headache to replace the tank to add the intake pump or just do a good inline pump?
Old Apr 25, 2013 | 12:50 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: carb to tpi fuel?
I seem to remember that GM, being thrifty, used the same tank in carb cars as in the EFI cars. The difference is in the sending unit assembly itself. In fact most of the factory carb cars had an electric booster pump in the tank to prevent vapor lock. I don't remember for sure about fuel lines on the carb cars. The TPI has a 3/8" supply, a 5/16" return and a 1/4" or 5/16" vapor line that went to the canister. You would definitely need to install high pressure fuel hoses wherever there is rubber fuel line.
I swapped TPI from an 88 Formula into an 84 Z28 but I think I used the tank and fuel lines out of the donor car.
Old Apr 25, 2013 | 03:10 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Well might as well drop the take and see what im working with thanks for he heads up.
Old Apr 25, 2013 | 03:33 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Cool.
Old Apr 25, 2013 | 06:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by obeymybird
l might as well drop the tank.
Always the budget method
https://www.thirdgen.org/forums/fabr...mp-access.html
Old Apr 26, 2013 | 12:58 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
True i did do this on my old bird. Also i have the holley hp efi i will be running on this im going to check that quick and see if it has a fuel pump hookup on it first.
Old Apr 26, 2013 | 06:22 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I hate people who cut up these cars just to avoid dropping the tank to replace the fuel pump. It's not that hard of a job. If you want to get away from dropping the tank, install an in line pump with a filter before it and replace the in tank pump with a length of braided hose. Then You never need to back in the tank again unless the sending unit fails. I'm so glad that no one ever cut up my baby. It would be different if someone actually took the time to do a clean job of this mod so that it looked like it was built this way. The ones I've seen have looked like backyard hack jobs.
The Holley ECM should have fuel pump control just like the factory ECM. It should have a relay in the harness package to power the pump. I got creative and used the relay in my ACCEL DFI to run two OE relays for my dual pumps.
Old Apr 26, 2013 | 08:06 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Yep it does has the relay built in and a power wire to hook it up. Well with the motor and trans and rear out should drop the tank and put a pump and everything in and wire it up and go with it.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
