86 t/a no fire
Old Apr 26, 2013 | 08:06 AM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
86 t/a no fire
Howdy yall, been doin the creep and lurking for a while but now need help.
I picked up an 86 t/a and she won't fire. Fires off starter fluid, but isn't getting fuel.
I pulled the rails and injectors, they aren't clogged and work, lines are clear, new pump,
new fuel filter, new battery, new fuel pressure reg.
The pump isn't activating, but has power. So, I wired it on a switch with power, it'll turn on now when I want, but she still won't fire. She sort of sounds like she wants to, but never does. getting 43lbs fuel pressure, all fuses are intact.
I came to the conclusion that the ecm was AWOL and not sending power to the injectors,
But this is my first GM so I wanted a second opinion.
On a side note, are there any pickups with compatible parts?
I'm trying to give her a couple inches of lift, was gonna jus drop in 1500 springs and struts, but need longer trailing arms and don't want to get custom made ones; she's a junkyard/mcguyver build. $600 car lol, the ONLY issue being that she doesn't run.
Any help appreciated, this is my work vehicle.
Old Apr 26, 2013 | 09:55 AM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Re: 86 t/a no fire
Get an ecm from the yard. Also the electronics in the injectors could've just gone bad from sitting and never being ran for years. check your connections and grounds and Check to see if the injectors are getting power or not.
Old Apr 26, 2013 | 01:20 PM
Car: 91 ws6
Re: 86 t/a no fire
The injectors themselves fire, I've applied 43lbs pressure and gave em 12v, they were plugged but are
fine now. Now, whether theyre firing properly, I don't know. I haven't had the chance to check resistance or use a noid tester yet. And based off a few searches, I'm seeing that the ecm is
Located behind the dash on the pass. side, correct?
Old Apr 28, 2013 | 03:50 AM
Car: 91 ws6
Re: 86 t/a no fire
Now this thing is throwing me in a loop. checked resistance on the injectors, all are between 16.1 and 16.4, used a noid light and all work. Now shes suddenly backfiring out the exhaust and intake simultaneously. Replaced pickup coil, ignition module, reset the timing, still nothin.
Back to faulty ECM?
Old May 6, 2013 | 06:49 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: 86 t/a no fire
sounds like your dissy is 180 out
Old May 6, 2013 | 06:58 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: 86 t/a no fire
OP said it would fire on starting fluid. If that means it ran for a few seconds, the distributor should not be 180 out.
Old May 6, 2013 | 06:41 PM
jamon8's Avatar
Engine: 350 tpi
Re: 86 t/a no fire
he just replaced the pickup coil and in order to do that you have to pull the dissy. everytime I have had it backfiring out the exhaust and intake it was 180 out.
Old May 6, 2013 | 07:49 PM
Car: 91 ws6
Re: 86 t/a no fire
I thought that too, I switched it 180 and everywhere inbetween, nothing changed.
Old May 7, 2013 | 06:26 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Re: 86 t/a no fire
OK I missed that. Still, as long as you mark everything, and don't crank the engine with the dist out, you should be able to reinstall without being 180 out.
Old May 7, 2013 | 09:16 PM
Car: 91 ws6
Re: 86 t/a no fire
Update, new dizzy cap, coil, spark plugs and rotor.
Re-timed dizzy correctly, she ROARS to life. then dies out, but will stay running on starter fluid.
Checked voltage at the pump, there's a short somewhere because its only drawing 3v, but still running
properly once oil pressure builds.
So back to not enough fuel pressure.
Injectors are good, I've pulled the rails and cleaned em out, blown out the fuel lines, new filter, and new (used) pump. wired the pump straight to a 12v line and still the same issue.
Check engine light still on, all fuses good to go.
Possibly the pump I got isn't putting enough pressure?
RS Reaper
Oct 17, 2018 07:52 PM
F-body-fan
Nov 4, 2015 06:13 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
