86 Camaro tpi running rich need help
Old May 11, 2013 | 02:21 PM
Lonnie w's Avatar
I bought an 1988 305 throttle body Camaro (manual), the guy i bought if off did an engine swap and the engine that's in it now is an 1986 305 tune port. Everything including the dash, wiring harness and computer minus the auto trani was switched out of the 86 and put in the 88. The only thing the previous owner did to the engine before dropping it in the 1988 was put a solid gear drive in it. He never got the car to fire, if you would spray starting fluid in it, it would start and shut off. When i got the car i pulled the tank, the hose from the pump to the metal line in the tank was rotted. i put a brand new fuel pump for and 86 305 tpi, the car starts, but now is dumping raw fuel. I replaced fuel injectors 19 lbs, fuel reg, fuel filter, throttle pos sensor, mass air flow sensor, cool temp sensor also replaced fuel pump again to see if i had a bad pump. It is still dumping fuel, and if i hold it at a steady idle it loads up, but if i give it full throttle it runs fine. When standing by the car it will burn your eyes and you can see raw black smoke. The scanner says running rich, send o2 sensor through the roof. i replaced it twice as well as tune up and oil and i am still getting the same reading (running rich) on the scanner. I need help before i end up putting a carb on it.
Note: it does have a hyper chip in the computer the guy says the motor ran fine before the swop.
Old May 12, 2013 | 07:20 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: 86 Camaro tpi running rich need help
what's your timing at?
Old May 12, 2013 | 09:45 AM
Lonnie w's Avatar
put a timing light on it put it right on do it by ear dosnt change any thing with it dumping fuel
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 02:00 PM
squiggy2
Aug 9, 2015 09:30 PM
