Negative Battery Cable/Fuel Lines
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
In the picture above, i have the negative battery cable attached to the fuel line bolt, just holding it, but where does it actually go, I don't remember? And that is where the fuel lines are suppose to bolt up to right?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Negative Battery Cable/Fuel Lines
It actually bots to the bottom of the power steering bracket should be t50 torx bit bolt thats the right spot it goes make sure u have good metal to metal contact
Ok, yeah I was having trouble finding where it went last night
Car: 1990 Trans Am GTA
It is a torx t45 on my '90 GTA. Which I found out after 3 trips to the auto parts store. I can only blame soarestransam for the first 2.
