HIGHEST flowing EFI SBC intake....PERIOD. I may be ditching TPI!
Old Jun 4, 2013 | 07:41 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Well, I have a strong feeling I am going to run TPI the rest of the Summer and then swap to something else. I KNOW I'm leaving a couple hundred horsepower on the table and that makes me want to step up and show what my combo is REALLY capable off. AS it sits right now, I am shifting at 6000 so that power doesn't drop off like a brick at 62-6300...
I have trapped 102 in the 1/8 boost only and tuning my meth in this week. I just want more. Isn't that how it always happens though?
Honestly, I am open to all different kinds of intakes. I figure if I am removing the TPI< I want the best thing out there.
Requirements
1) Make huge power to 7000 rpm with 20 lbs of boost
2) Fit under a small cowl
3) Easily allow front facing piping to connect to my piping already there.
4) Ability to run my 58mm Holley TB would be nice, but not a necessity.
I'm leaning towards the stealth ram because of it's simplicity, regular TPI style TB and ease of porting, but also been reading a lot about Edelbrocks Pro Flo intake.
Opinions?
Old Jun 4, 2013 | 07:52 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: HIGHEST flowing EFI SBC intake....PERIOD. I may be ditching TPI!
What cam and heads. Intake will help hold power on past peak better than conventional tpi but if still mild cam and small heads, may not make power much higher.
With that said, stealth ram has been good for many, but i got nervous about flow distribution and decided to sell it for single plane efi. For boost its hard to pass up single plane efi. Hsr will work and so will pro flo xt just keep an eye on front to rear cylinder distribution. I would install an o2 bunch on say cylinder 1 and 7 primaries and move wideband around to see what it does just to be sure. Read plugs as well
Pro flo xt i dont think can be easily opened to 1206 port, same with hsr unless you got one of the later bases with material around ports. Not sure what size your heads are
Pro flo uses round type throttle body similar to ls. Single plane with elbow uses whatever throttlebody you want as long as the mounting flange is correct. However most shelf available ones are for lsx throttlebody or ford
Old Jun 4, 2013 | 07:59 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Sorry, Its my blue Iroc. Figured everyone has heard enough of it already!
AFR 195cc
9/1 compression
solid roller 230/236 .552/.564 110 LSA
20 lbs of boost from a Ysi Vortech
Distribution was a concern of mine as well. TPI is bad about #7 as well!
After thinking of it. Single plane is MUCH better for boost as it spreads it evenly from the top as opposed to front inlet intakes....
Old Jun 4, 2013 | 08:05 AM
Guest
Guest
Posts: n/a
Get a F.I.R.S.T intake!
Old Jun 4, 2013 | 08:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Single plane may not look as pretty as some intakes but if you had a good elbow design feed the center plenum, distribution is pretty good. I did 2 tear downs on my motor and very happy with what i have seen with boost and cylinder to cylinder distribution so far.
Elbow should be a smooth 90 deg bend as large a radius as you can clear underhood. Center divider in the elbow also helps for distribution.
Can run ls1 type throttle body and directly swap in tps and iac sensor wiring to tpi harness. Just need ls1 sensors and connectors
Old Jun 4, 2013 | 08:34 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yeah, I have seen some weird things with front mount intake opposed to single planes as well...
I figure IF I'm taking of the TPI, I'm going for the most power possible. It's the only thing holding me back from a FAST streetcar to a Street MONSTER!
Old Jun 4, 2013 | 08:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah it should help. Curious why a solid roller over hyd roller on that build? Try playin with lash settings with the new intake to see if you can squeeze more top end power out of it. Maybe different exhaust lash since it seems more of a n/a cam instead of a blower cam. If gearing is good, car will fly with the increased top end power curve
Old Jun 4, 2013 | 08:44 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
We were building the motor in a different direction when we started. It was going to be a high revving turbo motor. This car sort of fell in my lap and we decided to keep the motor as is and put in here...
Old Jun 4, 2013 | 08:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Seems to work well enough. But i got a feeling new intake you will see less boost on the gauge but still be alot faster
Old Jun 4, 2013 | 09:01 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I'm sure of that. Boost is just a restriction and we all know TPI has a LOT of that!
I do have a smaller blower pulley
Old Jun 4, 2013 | 09:22 AM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
If you want high rpm, I would think single plane or miniram would be best.
Old Jun 4, 2013 | 01:09 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I just want the most usable power. I think a single plane is where Im heading
Old Jun 4, 2013 | 02:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Runners are still long enough on single planes to produce good torque. More than miniram and likely on par with stealth ram/pro flo.
You can use those intakes fine just saying be aware of possible distribution issues. May or may not have them. There were a few guys here i believe making more power than me with no issues it seems. Not sure what efi systems they are using, but they may have injector offset functions helping even fuel curve out. I am not sure
Old Jun 4, 2013 | 03:36 PM
GenX'Motorsport's Avatar
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
Very curious as to what youre latest dyno #'s are?
IMHO, Since im a Thirdgen Junkie, Id love to still see a TPI based intake of sorts under the hood of that "Mag cover car" a Stealth Ram or FIRST unit that hogged out to the max would be very interesting with youre current setup. And it would also make a goal for some of us to try to achieve
Old Jun 4, 2013 | 03:52 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Hard to beat a single plane intake for this set up.... I would not think twice about it!
Old Jun 4, 2013 | 03:54 PM
88gunmetalgta's Avatar
IDK about highest flowing, but this one from RHS has a ton of nice features when its compared to my Victor E manifold.
http://www.racingheadservice.com/rhs...ons-10142.html
I run Aaron's standard height intake elbow from 6061.com and a ported LS1 throttle body (LS1 TPS, IAC, and MAP sensor). No hood clearance issues and no air distribution problems whatsoever (then again, I am not FI yet).
If I were to do it again I'd run the RHS mani, Aaron's elbow, and a nick williams TB. The LS1 style tb's with progressive cable tracks improve driveability and idle control over a 4-bbl IMO.
Lots of LS guys are running tons boost through aaron's LSx elbow without any problems
Old Jun 4, 2013 | 03:55 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I am going back to tune in my meth and I will get those numbers. My TPI is as hogged out as you can get(within reason, meaning no welding, shortening of runners, etc))
I am going to keep the TPI throughout the Summer. 10s should be easy in the 1/4...BUT I know with a different intake 9's would be much more easily in reach!
Old Jun 5, 2013 | 11:23 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Well whatever you do don't bother with a Pro-flow XT, it looked nice but came with small intake ports like 1204 size and trying to port it bigger would be a real big hassle with welding and such. HSR, MiniRam or a single plane though the looks are not there if that means much to you would be the best options.
Old Jun 7, 2013 | 01:10 PM
Have you even looked at the FIRST unit?
Old Jun 7, 2013 | 01:50 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
yes, I have. I like the thought of the FIRST because of it's looks. I just don't think it will support my lofty goals like a single plane will...
Old Jun 7, 2013 | 02:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
As far a i know First arent in production at the moment and will be a longer wait until they get setup again. But i dont think it will match a single plane for power unless you siamese the tpi runners or have custom 2"+ diameter runners and big ported base. Not easy to do
Old Jun 8, 2013 | 10:57 AM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
A single plane would certainly be your best bet. A miniram may have distribution issues at your power and boost level. If you want to "experiment" with a miniram let me know. I have a beautifully polished unit that would look perfect under your hood
Old Jun 10, 2013 | 08:29 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
WOW! Very tempting
What kind of pricing would be involved for some experimentation?
Besides, I KNOW that this TPI is having problems with #7, it would surely be better than that
Old Jun 10, 2013 | 08:46 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Fwiw
Heres an old thread featuring an LT1 on boost and then switching to single plane efi
http://www.afbforums.com/index.php?/...-plane-intake/
Also my friends 520 whp n/a 406 runs single plane victor efi. Before he ran miniram and went 10.6 at 130. After single plane it made the 520 whp and ran 10.4 at 132. Miniram was not ported however.
Test the mini would be nice to see. Would see gains over tpi thats for sure.
Old Jun 10, 2013 | 08:56 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Nice Orr, that combo is VERY close to mine in the SBC, ysi, meth combo. Wow!
I am in the process of tuning in my meth on the TPI, so I will "max" out this combo before switching so I have as close to apples to apples as possible.
Moser 9" centers can eat it, UGGH!
Old Jun 10, 2013 | 12:14 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
You know I wouldn't charge you a dime to use it. It's all yours until I find a clean IROC to stick my motor in If you like it enough then we can talk turkey. I'll probably be stopping by Mayhem in the next week or so and I can drop it off with Will or Jay if you wanted to get started that soon. Its a 1205 gasket and the ports matched my AFR's perfectly. It's not as good as a single plane, but I picked up 7 or 8 mph on my turd when I swapped from the tpi intake.
What's going on with your rear? New center section noisy again?
Old Jun 10, 2013 | 12:31 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
yes...noisy on accel.....
Perfect, my heads are 1205 gasket matched..... as is my TPI intake.
I will get with you soon. Don't want it this week, but maybe soon !
Old Jun 10, 2013 | 12:57 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Just let me know. And not on facebook lol. I don't get those messages till a week after you send them. You going to re-do the center yourself now?
Old Jun 19, 2013 | 02:01 PM
kad5118's Avatar
Car: 91 gta ws6
Transmission: 700 R4 TRANS
why not try the hurricane efi single plane intake,from what i heard its bigger than the e vic junior and performs quite well.
Old Oct 16, 2013 | 10:47 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Going single plane for sure.
If you have any parts PLEASE let me know
Anyone know of a NICE elbow that will use my 58mm TB?
Old Oct 16, 2013 | 11:42 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Look at nitrous oulet/860 performance boosted lt1 intake elbow. Only one i know made to fit those tb's. else sell and go ls1 style
Old Oct 16, 2013 | 11:51 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yes. I have seen those, but $400 is HIGH!
Guess LS1 style wouldn't be too bad...
Old Oct 16, 2013 | 12:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yup. Exact reason i sold my holley 58 and went ls1
Old Oct 16, 2013 | 12:45 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
besides the sensor itself and connector do the LS1 IAC and TPS operate off of the same 0-5 volts?
Old Oct 16, 2013 | 12:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yup even have same color wires so cut and paste in very easily
Old Oct 16, 2013 | 08:00 PM
Guest
Guest
Posts: n/a
NO!!!! Just get a FFI intake!!!!!!!!!!!
Old Oct 16, 2013 | 09:38 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Can't. Tired of having my intake hold me up from maximum horses!
want BIG numbers now!
Old Oct 17, 2013 | 09:58 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
So, how did you run your TB cable with the LS TB and elbow. I think you are using one of Aarons intake elbows, correct?
Were you able to retain use of the TPI cable?
Old Oct 17, 2013 | 10:09 AM
Here's mine. I used a cable from a 3400 minivan.
Now I'm using Lokar cables and will eventually re-make my brackets out of billet and have them anodized.
Old Oct 17, 2013 | 10:32 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Using a stock 00-02 fbody throttle cable, i believe thats the year. Its longer than stock tpi because the linkage is on opposite side so i wrapped it around motor.
I do have one of aarons custom elbows but it did not have a bracket for the cable. So i made an L shaped bracket that bolts to the intake carb flange on top of the elbow. It runs straight up and i cut a u shape in it to slide the throttle cable end down into the bracket. Zip tie secured it for additional support as it popped off one day lol
Old Oct 17, 2013 | 10:39 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
OK. I'm sure I can figure something out.
I did notice that my painter painted the base of the tb cable when he did the engine compartment. I will have an issue if I remove it.
Old Oct 24, 2013 | 03:58 PM
  #42
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Got an elbow coming that should work with my current Holley TB. It was custom made and should allow use of my stock Thrttle cable as well.
That RHS intake looks NICE!
Old Oct 24, 2013 | 04:07 PM
  #43
Iknoright! Wanna buy my victor e? Lol
Old Oct 24, 2013 | 04:42 PM
  #44
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
hmmm, how much.....
Old Oct 24, 2013 | 06:07 PM
  #45
hmmm, how much.....
I have so much other stuff planned for this winter I prolly should keep it for the next season at least. shoot me an offer though if you want. It would be intake and fuel rails.
Old Oct 25, 2013 | 08:33 AM
  #46
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Just as a before I ran 6.84 @103 1/8 with TPI
1.55 60'
Old Oct 25, 2013 | 08:56 AM
  #47
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Dont be alarmed if you dont set records right away with same tune and driving style. Intake swap will change the power curve and require you to retune and relearn the launch method and shift points
Old Oct 25, 2013 | 09:10 AM
  #48
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Oh, I know.
Going to run 1/4 in November and get that number and a final dyno number as well. I just want to have as much information as possible before the swap, so I can see where I gained and lost at.
Old Oct 25, 2013 | 10:01 AM
  #49
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Tad more cam could help lol
Old Oct 26, 2013 | 10:14 PM
  #50
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I KNOW!
But, that's not changing
at least for now
