86 iroc idle is high.
Old Jun 14, 2013 | 10:15 PM
3rdgenowner's Avatar
Car: 89 camaro rs
Engine: 350 tbi
Hi guys,
When I first go out and start my car it will stay idiling at just over 1500 rpms, I know that's to high, it should be around 800 rpms....it is the 305 tpi.
What is the issue?idle set to high?
Thank you!
Old Jun 14, 2013 | 10:49 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 iroc idle is high.
that is a little excessive you should be around 1,100 rpm on cold startup. Start with setting your minimum idle speed and resetting the tps followed bye looking for vacuum leaks.
Old Jun 14, 2013 | 11:02 PM
Car: 89 camaro rs
Engine: 350 tbi
Exactly, how do I go about setting that?I have never messed with a tuned port engine before.
Thanks.
Old Jun 14, 2013 | 11:04 PM
Engine: Lb9
Transmission: M20
http://www.iroczone.com/2009/10/adju...ir-idle-speed/
http://www.iroczone.com/2009/10/adju...on-sensor-tps/
Old Jun 14, 2013 | 11:30 PM
Car: 89 camaro rs
Engine: 350 tbi
Very helpful and informative. Thank you buddy!
Red iroc-z 305
Sep 30, 2015 05:22 PM
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
