350 tpi running extremely rich.
Old Jun 30, 2013 | 02:45 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
I have a .40 over 350 with lt4 hot cam1.6 rockers, stealth ram, 52mm tb, EQ 190 vortec heads. Timing is set and the injectors are the factory 350 tpi injectors. I have the egr and vss deleted from the ecm. The esc is also jumped because it was converted from maf to speed density. The car runs extremely rich. Rich enough that it smoked like a Deisel when it was on the dyno yesterday. The check engine light also comes on if I cruise at a consistent speed over 40 for more than a few minutes, I'm assuming that's map related. The car only made 240/270 on a dyno jet yesterday, and I'm assuming that's because of how rich it is. Is a tune all I need to lean the car out? Or is there something else causing it to run rich?
Old Jun 30, 2013 | 03:47 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 350 tpi running extremely rich.
Before you start with the tune, datalog and look at your, cts, tps and map. Also check for obvious things suck as retarded timing and leaking fpr and injectors bleeding off the fuel pressure fast koeo.
Old Jun 30, 2013 | 07:01 PM
RyanJB's Avatar
I'd imagine if anything the timing is too far advanced
I hooked the car up to the datalogger today, the computer wouldn't communicate...
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
