TPI An unusual problem. Please help. Fuel Pump
Old Jul 9, 2013 | 04:41 PM
lethaldomestics's Avatar
1987 Firbird 305 TPI
Fuel pump always runs and i cant figure it out ive searched and searched
With everything unplugged ( fuelpump relay and Oil pressure switch) Pump still is always on.... tried a new relay also still no luck. I have to unplug the weatherpacked fuse to get to shut off. when i fire her up she stumbles a bit and when driven she sometimes bucks. loss of power.
Every sensor new except op switch. i was told that with the op switch unpplugged it would shut down the fuel pump. No go tho. cant figure why the pump wont shut off.
she used to chirp into second.....haha. I refuse to drive it like this because it dont feel right, and i may cause further damage.
Thanks guys once again
Old Jul 10, 2013 | 11:03 AM
Re: TPI An unusual problem. Please help. Fuel Pump
Bump
Old Jul 10, 2013 | 11:36 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Has it always been like this or has it worked properly before?
You might check the wiring. Maybe someone put a 12v run hot wire to the pump wiring.
Old Jul 10, 2013 | 12:52 PM
yeah it just started acting up about a month ago. it did run properly before. i will be putting in a new pump when i do my rear end swap. but from what i know that wont fix this issue.
I also want mention when i plug the weather packed fuse in i can hear a bubbling noise in the fuel rail for a few seconds. never did this before.
Fireturd350 as far as i can see there is no extra 12v run hot wire rigged , that i can see from engine bay or under car.
Old Jul 10, 2013 | 09:18 PM
Bump
Old Jul 12, 2013 | 10:07 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
It sounds like you've tried everything. Just to clarify, you unplugged the OP switch behind the distributor ( not the one by the oli filter)? that's about the only other thing I could think of, except for a wire getting 12V from somewhere it shouldn't...
Old Jul 15, 2013 | 11:06 AM
yes i unplugged the op and the pump still runs.
Old Jul 15, 2013 | 11:48 AM
Engine: 383 SBC
If it ran correctly before. It has to be either a sensor that is bad somewhere, frayed wire, relay, or run-hot only wire that is making a connection where it shouldn't. You'll just have to start tracing wiring back to see what is tripping the relay or has frayed that's causing the issue. Wiring problems can sometimes be a real pain to find. It took me 2 weeks just to figure out I forgot a ground wire that fell down ontop of the transmission bellhousing out of sight that was required for my speedometer to work.
Old Jul 15, 2013 | 12:56 PM
i will look into it this week some time.
Old Jul 17, 2013 | 02:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Have you checked the connectors themselves to confirm power is not passing direct from the batt to the pump
The early non weatherpack connectors have a habit of loosing the insulation allowing shorts to ground or relay bypass when the wires touch
Old Jul 17, 2013 | 07:49 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
IIRC, there is a way to jump power to the fuel pump through the ALDL connector. You may want to look there as well.
Old Jul 17, 2013 | 11:17 AM
Yes my weather pack does have some insulation missing i will post pictures soon.
i will also check the aldl also.
I will keep updating this post until i figure it out.
Old Jul 19, 2013 | 09:00 PM
OK. so i wiggled all the relays nothing..... Then i wiggled grabbed the wire harness behind the motor and sure enough it shut the pump down. found my problem. Now would this cause running issues at idle? stumbling ect?
Cause i figure it might not be my running issue because i think the pump is supposed to run full time anyways while engine is fired up.
I'm also worried about having to replace the harness.... Any suggestions?)
Thanks guys, as always a big hand indeed.
Old Jul 19, 2013 | 09:01 PM
Mine look exacly the same
Old Jul 20, 2013 | 06:20 PM
Anybody?
Old Aug 12, 2013 | 11:43 PM
A 2010 as a rat rod
Old Aug 12, 2013 | 11:47 PM
wrong thread whoops
i meant to say i fixed the issue with the wire grounding out. had to pull harness back and make repairs.
NOW I HAVE A WHOLE OTHER SET OF ISSUES!!!!! AHAHAHAHAHA
Old Aug 13, 2013 | 03:50 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
1. Where exactly are the connectors from the above pics located? I need to check them preemptively on my car.
2. As I recall the oil pressure sensor serves as a backup for the fuel pump relay when that relay dies. Perhaps your relay died and the oil pressure unit is also defective, resulting in this weird combination?
3. Bubbling in the fuel rails? The fuel from the rails usually returns to the tank when the engine is shut off, at least so much that the pressure reduces itself. So the sound may be normal when the pump primes the lines and sends fuel into the rails to build pressure. If you suspect your running issues to be fuel related, you may want to check the fuel pressure regulator for issues.
Old Aug 14, 2013 | 02:30 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Somebody else's pic
Old Aug 14, 2013 | 02:35 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
That would result in a open circuit giving no power to the pump.
Other than a wiring fault injecting 12V into the pump circuit , the only way to get the pump to run fulltime is for the relay
or the OP switch to be permanently in the closed position
Old Dec 7, 2018 | 02:15 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Looks like after reading the rules as long as it sits in a structure it will be legal. Sounds like your chassis guy is on it.
In for pics for sure!
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
