bolt on HP?
Old Aug 7, 2013 | 04:41 PM
racerx520's Avatar
bolt on HP?
how much power do you think would come out of a rebuilt 350 tpi at 10:1 compression, new cam and some slp intake runners?
or any other bolt ons for power. it'll be too expensive to bore out the motor to 355 and rebuild it as that so we're probably going with just a 350 (as long as the cylinder walls are within tolerance) and once the bottom end is built, its gonna get the original heads again probably and then some bolt ons. looking for recommendations and how much power you think.......kinda wanting to be around 350hp
Old Aug 8, 2013 | 08:08 AM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Re: bolt on HP?
See my thread. I did not do anything to the heads or change cam.
https://www.thirdgen.org/forums/afte...s-any-one.html
Old Aug 8, 2013 | 08:56 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: bolt on HP?
I would say between 200 and 400hp
Old Aug 10, 2013 | 04:20 PM
racerx520's Avatar
Re: bolt on HP?
I looked at your thread, so how much hp did you wind up running at the end? So far im thinking the crane 2032 cam (unless theres a better cam for it), edlebrock intake runners, maybe an electric water pump, underdrive pullies? but i'll transfer over my hooker shorty headers to the 350 fromthe 305. I was also going to port and polish the intake manifold and the plenum. Any other ideas? i'm trying to do cheap-ish bolt on stuff.
what about the fuel injectors? i think i had to replace 2 or 3 last time i had to to the intake manifold so i still have a stockers. stock poundage though?
Oh! and doing a chip too for it. and isnt there somewhere to get a new prom written for the computer too?
Old Aug 10, 2013 | 05:13 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Re: bolt on HP?
My final numbers are 254HP and 360 TQ At the rear wheels. Figure abour 18% drivetrain loss and you get close to the flywheel numbers. Original Stock injectors. I had TPIS do the chip for me as it was their intake and runners I used. That's 40 Rear wheel HP gain and a 70 rear wheel TQ gain.
Old Aug 10, 2013 | 05:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: bolt on HP?
Originally Posted by racerx520
what about the fuel injectors? stock poundage though?
With the limited budget you appear to be working to for your build you won't need bigger injectors
Just get a memcal for the same year 350 engine and a 350 TPI knock sensor to replace your 305 unit
Old Aug 10, 2013 | 10:15 PM
racerx520's Avatar
Re: bolt on HP?
cool, thanks guys. you guys think MSD is a worthwhile upgrade too? I'm not sure if MSD is going to do any good for the setup i'm looking at.
Old Aug 10, 2013 | 10:25 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Re: bolt on HP?
Not a thing...Unless you have a bad coil.
Old Aug 11, 2013 | 04:21 PM
racerx520's Avatar
Re: bolt on HP?
coil from the 305 is stock, and the original. I was considering msd coil, distributor, cap/rotor and the high flow plug wires. this is gonna be a project which will take me until next fall i think so i'm willing to put a few bucks into it.....just not making it a race motor.
Old Aug 11, 2013 | 08:15 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: bolt on HP?
you guys think MSD is a worthwhile upgrade too? .
Not with the failure rate of the current asian made MSD products
Do a Google search about MSD problems
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
