Code 43 I'm out of ideas
Old Aug 20, 2013 | 09:56 PM
Trkdrivr's Avatar
Car: 90 firebird
Engine: 87 tpi 5.7
Transmission: 6 speed
Poor electrical connection, open or short in circuit, defective esc module, defective knock sensor, defective ECM.
That's what the book says. I've replaced the following or tested,
Tps
Iac
Ecs
ECM
Distributer
Plugs
Wires
Maf burn off relay
Knock sensor
Egr valve
Egr solenoid switch
All fuel injectors
Rebuilt fuel pressure regulator
Distributed cap and rotor
Coil
I'm probably forgetting something but that's what I remember right now. This car used to be a v-6 car with auto trans and one ledger rear end. It is a 1990 firebird. It now contains a 5.0 bored out to 5.7, t-56 and posi rear end. Wiring harness came out of an1987 firebird and engine came out 87 iroc. Trans and rear end are out of 1994 formula. I've got everything working except speedo and this ghost I'm chasing through the engine compartment. Car runs great until you go into 5th on the way up through the gears then it feels like it loses power and when you let off the throttle, there's the good ol check engine light. Code 43. Any ideas? I'm fresh out.
Old Aug 21, 2013 | 01:44 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Code 43 I'm out of ideas
what the book says
But did you work through the code 43 fault chart completely to narrow the problem down ?
See
http://www.chevythunder.com/maf_esc_module_code_43.htm
Old Aug 21, 2013 | 07:47 AM
Trkdrivr's Avatar
Car: 90 firebird
Engine: 87 tpi 5.7
Vetteoz, thanks for the flow chart. I'll be checking that a little later today.
Old Aug 22, 2013 | 11:37 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
POSSIBLE EGR COMING ON?
5TH GEAR ONLY RIGHT?
Old Nov 3, 2013 | 11:23 AM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Ever figure it out?
1992Vortec
Aug 31, 2015 08:05 PM
mdtoren
Aug 23, 2015 12:52 PM
GouldyGTR
Aug 21, 2015 10:43 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
