Changing my mind....
changing my mind from the crane 2032 due to the price (could have sworn it was like $380 like 2 weeks ago, not like $500+)
I already had a prom written for my unbuilt motor, i told them i was going to be putting the crane 2032 in, anyone have any suggestions for something nearly identical minus the pricing? thanks
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Changing my mind....
http://www.ebay.com/itm/COMP-CAMS-87-98-CHEVY-SBC-268-XFI-COMPUTER-ROLLER-CAM-/360724666524?pt=Motors_Car_Truck_Parts_Accessories&hash=item53fcdd989c&vxp=mtrhttp://paceperformance.com/i-6497433...-take-out.html
On your tune unless it is one the tuner has done live or off datalogs with the same build it will need some minor tweaking.
Comp Cams 87 98 Chevy SBC 268 XFI Computer Roller Cam | eBay
How will the comp cam work with the computer though? i youtube'd some vids of the comp cam in the TPI and it sounds like it wouldnt work at all it with a computer.
i've also seen people changing the valve springs for this cam...would ineed to do that even with the summit heads? what about any other work that might need to be done? i'm pretty interested in the XFI now, just need to find out what i need to do in order to get it to work for my car. Any advice is greatly appreciated! thanks!!
Engine: Lb9
Transmission: M20
tpi maf is more forgiving with camshaft change but it depends on what injectors you install. Say you put 30#hr injectors with a stock 350 or 305 calibration you will have decent power but idle it will run super rich. You don't give any detailed engine information.
The comp cam is cumpter compatable but you can allways improve on the tune.
I'll be transferring my hooker headers from my 305 to the 350 also. I am not sure what to do for the injectors, I may just go with stock size, but I know the ones in the 305 are mostly original at 178k miles. the motor will keep the MAF setup and I have a custom chip burned in order to shift the timing ahead and hopefully pull a few more h.p.
The car already has 3.73:1 gears installed also. I'll also try to port/polish the intake manifold as well. I am hoping to try and get atleast 350 hp out of the car. I am unsure if those listed summit heads will need any additional work, I have seen posts of people needing new sized pushrods and different springs too.
Engine: Lb9
Transmission: M20
The heads as they are listed, * 1.25 in. diameter valve springs (0.480 in. maximum lift)
Engine: Lb9
Transmission: M20
Or rethink your head and cam choice.
http://www.ebay.com/itm/AFR-1034-SBC...-/281199443561
