TPI tank to filter rubber line length
Old Aug 21, 2013 | 04:30 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
anyone have any measurements or anything?
Old Aug 22, 2013 | 10:35 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI tank to filter rubber line length
If your asking the total length from the high pressure crimped on flex line to the filter is 2ft 7", the saginaw female 16mm o-ring flex line is 7 inches from the end of the fitting to the end of the line crimp. If you are needing to replace the flex line you can use a earl's
9894DBJERL to convert to an6 then build a an -6 flex line and double clamp it on the hard line or flare the hardline to an 6 and use a tube nut.
Old Aug 23, 2013 | 01:00 AM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
or have inline tube make me one thanks TP
Old Jul 21, 2015 | 04:45 PM
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
oops.. didnt mean to bump this.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Sanjay
Aug 12, 2015 03:41 PM
