TPI on GW290hp with 113 heads....
Old Aug 25, 2013 | 07:34 PM
knight123's Avatar
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
So I have a few questions I'm hoping people here are interested in sharing their answers with me...
Background - after finishing my restore on my 88 formula I got that tinkering feeling again that I needed to satisfy.. So after doing months of reading on TPI builds using various gen1 SBC's I got the chance to buy a hecho en mexico 290hp with 10k miles on it. It was built in 1981 according to the serial for $200. So I bought it and while deciding what to actually do with it I got the chance to buy a set of 113 heads with a fresh valve job and porting for $200. That set the stage for a 350 swap for my Formula.
Currently the plan has been to strip the old heads off, check everything out, leave the cam in it and add the 113 heads with a ported corvette intake, runners. I got this far and added 1:5 roller rockers, when the engine goes in I have hooker 2055's to add.
So knowing this what are the opinions on the TPI liking this cam in this engine?
Also I should be about 10.2:1 compression with the aluminum heads do you think I can run 93octane without getting too much computer timing retard?
I have a 88 350 prom and with the MAF do you think I will need a custom prom?
I'm hoping for 350hp at the rear, is this doable with this setup?
Any other general comments that could help me along?
I know I could have gone with better heads but for about $600 total I'm hoping to add 100hp over my 305...
Old Aug 25, 2013 | 10:10 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: TPI on GW290hp with 113 heads....
What cam? 350 at the tire is going to be tough to do
Old Aug 25, 2013 | 11:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
This built 383
http://xtremecarzone.com.au/index.php?showtopic=386
with aftermarket TFS heads and big cam only made 400 Hp at the flywheel with a TPI ; less driveline losses = how much at the wheels ?
FWIW;
the "Corvette" TPI intake has no difference over a 3rd Gen one except for a different EGR setup
Old Aug 26, 2013 | 12:01 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The corvette intake does have the rear coolant crossover, 350 at the flywheel with a good cam no way your going to get 350hp at the rear wheels with drive train loss. the 113 heads like more SA tuning it when your done will be well worth the effort. With a zz4 cam and 9.5 comp I got a customers car to pick up 20hp and 40tq.
Old Aug 26, 2013 | 07:08 PM
knight123's Avatar
Engine: 5.7 TPI
Camshaft Lift: .450 Intake /.460 Exhaust
Flat Tappet Duration @ .050" (222°Int/222° Exh
This is stock cam this engine ships with. Its a flat tapped cam not a roller one.
Old Aug 26, 2013 | 07:19 PM
knight123's Avatar
Engine: 5.7 TPI
Originally Posted by vetteoz
This built 383
FWIW;
This a great article I've never read before. I need to print this out and read like 30x to really understand what they are showing here.
So to be clear I have the stock base mildly ported, the stock runners have been expanded to about 1.68 inches with the ends ported to remove the lips there. I also gasket matched the intake to the heads (I was surprised by how much material on the intake had to be removed)
Stock plenum and 48 throttle body.
If you had to estimate where I would be for hp? Let's use crank to eliminate the driveline losses.
Thanks for replying!
Old Aug 26, 2013 | 07:29 PM
knight123's Avatar
Engine: 5.7 TPI
Yeah I have the crossover little pipe blocked but the crossover has the open port gasket. I have Bosch lll 22lbs that will go on with an adj fuel regulator. I'm worried about timing with the high compression but hoping the aluminum heads help with detonation with faster heat transfer.
Old Aug 26, 2013 | 07:31 PM
knight123's Avatar
Engine: 5.7 TPI
Also forgot I have a set of roller rockers 1:5 on there as well not that they would add too much additional hp.
lt500r55
Sep 1, 2021 01:30 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
