Racetronix fuel pump kit
Old Sep 13, 2013 | 09:56 PM
KyleP's Avatar
Car: 99 SS 86 IROC
I am trying to get my fuel pump kit installed and unfortunately I didn't recieve any instructions. Do any of you guys know how the bulkhead conector goes.
Old Sep 13, 2013 | 10:15 PM
KyleP's Avatar
Car: 99 SS 86 IROC
Re: Racetronix fuel pump kit
Here is another pic
Old Sep 13, 2013 | 11:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I'm not sure if your asking what wire goes to what side of the factory tank harness. But the red hot lead log your pump goes to the grey wire and black to black.
Old Sep 14, 2013 | 08:15 AM
KyleP's Avatar
Car: 99 SS 86 IROC
Thanks for the help man. Any idea how the bulkhead connector goes. Does it replace the factory harness on the sender?
Old Sep 14, 2013 | 08:31 AM
Engine: Lb9
Transmission: M20
racetronics has a forum you can sign up for free with proof of purchase. the kit says plug and play. this may be a generic picture, but the ecm needs to control the relay I assume the harness is ran on the sub frame to the old fuel pump relay connecter.
http://www.racetronix.biz/itemdesc.a...%2D005&eq=&Tp=
Old Sep 15, 2013 | 01:25 PM
KyleP's Avatar
Car: 99 SS 86 IROC
The kit comes with wires that replace those going from the bulkhead to the pump. What is the best way to ground that wire?
Old Sep 15, 2013 | 03:02 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Post a pic and part numbers of what your replacing.
You could also E-mail them for the instructions. I thought they used to have them on the site??
Old Sep 15, 2013 | 07:33 PM
KyleP's Avatar
Car: 99 SS 86 IROC
It is http://www.racetronix.biz/mmWEBSTORE...s/BCWAFL98.jpg
Old Sep 15, 2013 | 08:10 PM
TTOP350's Avatar
Fairly certain your going to have to cut the ground wires to remove the old sending unit harness.
When you do, leave plenty of wire on the existing ground to splice your new connector back onto.
Old Jun 8, 2014 | 08:12 AM
KyleP's Avatar
Car: 99 SS 86 IROC
I've got everything going I just can't get my gauge to work. I am hoping its a ground. I have bought a new sending unit the original was very rusty. I am guessing it must be a ground. The kit comes with a band clamp that you put around one of the fuel lines on the sending unit to ground it. I have read about a ground at the back seat but I don't see it. Have any of you ran into this?
Old Feb 4, 2022 | 08:42 PM
AlpineWhiteIroc's Avatar
Car: 1986 Iroc-z
Engine: 10:7:1 Iron LS1
Axle/Gears: 4.10 Eaton True Trac
so nobody has any clue how you're properly supposed to install the bulkhead connector harness ...?????
bunch of outdated threads that leave you with no answers
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
92camaroJoe
Aug 13, 2015 06:07 AM
