fuel pressure drops randomly when off
Old Oct 7, 2013 | 11:57 PM
danielr1211's Avatar
Car: 90 iroc
Engine: Vortec 355 w/HSR
I have a 355 vortec stealthram with bosch 3 24lb injectors. I have a new kirban fpr set for 45lbs with no vaccum and am having a problem with keeping fuel pressure in the line. ive done some searching and havint come across any post where the fuel pressure will hold sometimes and other times will drop to zero and wont hold at all. im sure im just searching some random crap that no one else would word the way i do and im not sure where to attack this monster at i want to lean more to a fuel pump due to the fact the car has 170k on the body and im not sure when the fuel pump was last replaced. some input would be much appriciated before i haul off and buy a fp
Old Oct 8, 2013 | 02:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fuel pressure drops randomly when off
Originally Posted by danielr1211
fuel pressure will hold sometimes and other times will drop to zero ..
How fast does it drop?
Have you done the fuel supply tests to determine if the supply ( check valve ) or return ( reg ) side is bleeding off ?
FWIW
, my Aeromotive AFPR don't hold any pressure once the pmp is off
Old Oct 8, 2013 | 02:19 AM
Car: 90 iroc
I recently replaced the fpr with a kirban adjustable. It depends though sometimes after shut off the fuel pressure will hold for a while and other times it will bleed off instantly. It runs fine and other times the fuel pressure gauge will flicker rapidly back and forth an it runs like crap. Iv pinched off the return line and the pressure would still drop and when I pinched off the supply line the pressure would rise. I don't know what the fuel supply test is though.
mdtoren
Aug 23, 2015 12:52 PM
wayshegoes
Aug 17, 2015 12:00 PM
mdtoren
Aug 16, 2015 05:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
