Troublecode 34 and solution - 86 Camaro 305 TPI
Old Oct 21, 2013 | 12:07 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Old Oct 21, 2013 | 06:58 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Troublecode 34 and solution - 86 Camaro 305 TPI
Originally Posted by Chevy86 IROC-Z
i already have the FSM .what i need is to be able to test the MAFs that im getting from auto zone. i need to be able to test the MAF .not the car
Old Oct 21, 2013 | 07:20 AM
Car: 86 IROC
Engine: 5.0 TPI
trouble code?? yes. solution?? NO!!
Old Oct 21, 2013 | 07:57 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Did you check to see what memcal you have ? this could be a false code.
https://www.thirdgen.org/forums/diy-...inal-prom.html
Old Oct 21, 2013 | 10:06 AM
Nobody has a solution or a definite answer. Its up to you if you wanna figure it out. I went out of my way for you, hence guide for process of elemination. GOOD LUCK!!!!!
Old Oct 22, 2013 | 07:39 AM
Car: 86 IROC
Engine: 5.0 TPI
im not being a smart a$$.and i thank you for taking the time to post that up for us who are battling this prob.i should have elaborated a lil more ,i guess. i should have mentioned that i have the FSM for my car.i have tested everything and its brother ad nauseum.i find it hard to believe that all 7 MAFs that i have bought for it so far have all been rebuilt in china using rice ***** and dirt dauber nests.and although the MAF is still available from GM ,its price is $1,096.a deal breaker there ,for sure.so far i have been dealing with "vato zone".and that could be the problem ,i dont know.im going to go with the 8th MAF from oreilleys,its a re man unit from BWD. $175. what gets me is this, code 34 is saying MAF signal voltage low.but i have 12v on the red wire and 5v on the green wire and the two grounds are reading very little resistance.so.......it should function as intended,right?? not so, im afraid. im going to park it for a while (which pains me badly)maybe more research is needed.any way when and IF i get this fixed i WILL be posting up what was wrong and how i fixed it.again thank you for taking the time to try and help me
Old Oct 22, 2013 | 10:42 AM
Hey man. Dont worry man. Its all good. Try cleaning out the terminalson the connector. Use a tiny jewelers screwdriver to clean off the inside of the female connector on the harness side. Maby it has a bit of corrosion or oxidation to the point that its not making a good connection. I kept getting a code 33 until I cleaned the connector up. Since then, no more troublecodes.
Old Oct 30, 2013 | 10:59 PM
Any luck rusty vango?
Old Oct 30, 2013 | 11:03 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Late to the show here but have you replaced the maf power and burn off relays?
Old Oct 31, 2013 | 03:33 PM
Car: 86 IROC
Engine: 5.0 TPI
luck?? now it shows both code 33 and 34. im going to throw $100s at it till its fixed,im afraid. next up is to replace the ECM and the PROM.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
