85-88 vs 89-92 Throttle Body Differences
Old Dec 9, 2013 | 08:02 PM
Warrior's Avatar
Car: 98 Camaro/85 Camaro
Engine: 3.8L/ 355 CI
Transmission: Auto/ TH350
Axle/Gears: 3.23 Posi
Can someone please explain to me the physical differences between the 85-88 TB IAC and 89-92 TB IAC? How does the flow work since the later TBs do not need the hole in the plenum while the earlier ones do? Hopefully someone knows enough and can maybe share some pictures with the details. I am looking for a third gen throttle body for a drag application limited to stock size and trying to figure out which is superior. Going to use a custom manifold that is completely open so either should work. Throttle cable difference means nothing to me. The only concernable difference I have been able to research is the IAC difference but have not been able to find any detailed discussion on how the change affects anything.
Old Dec 10, 2013 | 01:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 85-88 vs 89-92 Throttle Body IAC Differences
Don't know about any IAC differences but the hole behind the TB on the early plenums supplies air to a port in each runner for the CSI which was deleted on the later setups
Old Dec 10, 2013 | 09:18 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/tpi/...t-iac-use.html
A 89-92 tb can be used on any year plenum. if you only have a 85-88 tb you can drill a 3/8 through the plenum to get the manifold vacuum signal. Or remove the section in the throttle bore to the iac passage like the 89-92 tb uses.
Old Dec 10, 2013 | 11:32 AM
Warrior's Avatar
Re: 85-88 vs 89-92 Throttle Body Differences
Sorry I was pretty tired last night when I propsed this question and I guess I did not ask correctly so I will try again. I am not interested in IAC motors/solenoids or housings.
To put it plainly, the 85-88 TB needs the hole in the manifold to sense vacuum (thanks Tuned) so it cannot work with all manifolds as is. I get that. What I don't get is what is different with the 89-92 TBs. So how does the 89-92 TBs get vacuum? How does this flow/sensing of air work? What is the difference between the two? I've never had either in my hand to compare and I am coming up empty finding pictures of the back side of a 89-92 TB.
Next question: does the fact that the 85-88 TBs need a hole make any performance difference due to air flow compared to the 89-92 that doesn't need a hole?
Hopefully that reads better??
Thanks!!
Old Dec 10, 2013 | 11:38 AM
Engine: Lb9
Transmission: M20
this is the back of a bbk, stock 89-92 is the same there is a cut out about 1/4 deep to connect to the throttle bores from the iac port to the throttle bore. It have converted a few tsb be careful at the bottom it is thin the angled piece at the bottom next to the iac coolant port.
Old Dec 10, 2013 | 11:44 AM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/engi...y-89-92-a.html
Here is a actual 89-92 tb pics
No performance differences with how the iac controls the idle with a controlled vacuum leak.
Old Dec 10, 2013 | 11:53 AM
Warrior's Avatar
Awesome! That is exactly what I have been searching for! Thanks a lot!!
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
