FIXED: EGR delet, just block off intake?
Old Dec 27, 2013 | 12:32 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I am doing southbay and I have access to EGR
I had 2 EGR diaphrams? one mounted to the intake with 2 ports and a sensor and a 2nd diaphram hooked up to one side of the vac port then other to the solenoid. IS this normal?
I have block off kit but I assumed it would have a plate for intake and 1 for exhaust. I do not see and exhaust port to the EGR? Is this ok can I just plate off the EGR at the intake, remove the sensor and vac lines and just remove in tuner pro?
Thanks that was it,
Old Dec 27, 2013 | 03:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: EGR delet, just block off intake?
There are 2 holes on the intake ; one is the feed from from the exhaust port
and one goes to the intake
The EGR valve connects the 2 when it operates
The one block-off plate seals them both
Old Dec 27, 2013 | 03:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You have the EGR valve located on the plenum
and the EGR solenoid that operates it by controlling the vac supply
Old Dec 27, 2013 | 11:11 PM
jjcuff1's Avatar
Thanks for the info.! OK I get the exhaust/EGR in the intake plate
and I know I have the egr solenoid but I also have 2 diaphragms maybe a PO add-on?
see pic
Old Dec 28, 2013 | 08:38 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
^WTH? NEver seen that before!
Old Dec 28, 2013 | 08:49 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Wtf? That's about the strangest thing I've seen done to one of these motors.
Old Dec 30, 2013 | 11:12 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
interesting and strange
never seen anyone that wanted to run two egr valves! lol
Old Dec 30, 2013 | 12:22 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Now I have seen everything lmao
Old Dec 30, 2013 | 12:42 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Holy guacamole!
Old Dec 30, 2013 | 05:57 PM
jjcuff1's Avatar
I removed the runners and painted the valve covers
I am going to tape off the intake base and paint it all alumn before I swap injextors
I will polish the runners and polish top of the plenum and area and spray the rest in aluminum color
Old Dec 30, 2013 | 09:08 PM
Car: 1971 Camaro
Engine: 427
You gonna get rid of the extra egr valve?
Old Dec 30, 2013 | 09:24 PM
jjcuff1's Avatar
It wasn't a 2nd egr it was connects inline of the egr valve vacuum line. Maybe it was a vac booster for a worn out egr?
Yes I am removing the egr n solenoid setup
mdtoren
Aug 23, 2015 12:52 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
mdtoren
Aug 16, 2015 05:45 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
